It is currently Tue Mar 03, 2015 11:48 pm
 Post subject: Overclocking 6800GT
PostPosted: Thu Sep 30, 2004 10:38 pm
Hey, I'm new to overclocking so I thought I'd start with my video card.
Could you guys tell me which applications you use to overclock your cards and why? I appreciate any positive feedback.
PostPosted: Sun Oct 03, 2004 7:53 pm
I overclock to get more FPS! Pretty basic cause. Make sure you use RivaTuner though. I think it's the best video card overclocking utility. Also, if you overclock it too much, you see articacts (little odd colored or missing pixels). By then you should back off a bit on the OCing. And, even if you dont see artirfacts, you may be OCing a little more than the optimal amount, becaause the heat generated might slow it down. I usually run 3dmark 2001 SE and test my video card on different settings to see on which frequency setting I get the best FPS. Remember, even if you dont see any artifacting, higher OCing is not always better. I've learned that from my experiences.
PostPosted: Sun Oct 03, 2004 9:28 pm
No Hope = No Fear
No Hope = No Fear
I use Power Strip by EnTech...
Here is a screenshot of my personal settings.
PostPosted: Tue Oct 05, 2004 10:17 am
I personally prefer coolbits when OC'ing my vid card. I also overclock for better framerates. Just be careful and be smart. Don't get greedy with the speed either, thats a sure way to screw things up, though coolbits actually resets the settings if they become unstable. My two cents.
