It is currently Sun Apr 26, 2015 5:32 am
 Post subject: Rate my System please
PostPosted: Thu Jul 01, 2004 3:56 pm
Hi everybody, new here and wanted to see what you all thought of my system....Self built
3.2 Ghz 800mhz FSB
Abit IC7-max3 mobo
480watt PS
1gb ddr ram, 400mhz
western digital 120 gig HD
cd rom
dvd burner
peace
PostPosted: Thu Jul 01, 2004 4:05 pm
i would take it
 Post subject: Re: Rate my System please
PostPosted: Thu Jul 01, 2004 4:17 pm
Astro lube 2 the MAX!
3.2 Ghz 800mhz FSB
Abit IC7-max3 mobo
480watt PS
1gb ddr ram, 400mhz
cd rom
dvd burner
peace
i would rate is a good high range pc system today.
PostPosted: Thu Jul 01, 2004 5:01 pm
excellent system. what videocard are you running?
PostPosted: Thu Jul 01, 2004 5:36 pm
Forum's Goatkeeper
Forum's Goatkeeper
not bad at all, that's about what I'm running myself :)
PostPosted: Thu Jul 01, 2004 7:08 pm
better than mine :(
PostPosted: Thu Jul 01, 2004 7:25 pm
Contributing Writer
Contributing Writer
Very capable system, you've the best in regards to i875 mobos. As someone else mentioned, what video card are you running? Also, are you into overclocking at all? A P4C on an IC7 MaxIII is just begging to be pushed :D
PostPosted: Thu Jul 01, 2004 8:31 pm
Yep looks like the system i ordered. Exceept with a different mobo. But you system is very nice!
PostPosted: Thu Jul 01, 2004 8:32 pm
not bad what about sound and video and what type of ram (amount/#of dimms)
PostPosted: Thu Jul 01, 2004 9:01 pm
Well, for now, im using onboard sound but I plan too remedy that with a soundblaster Audigy 2zs and I cant believe I forgot, A Geforce 5950 Ultra
PostPosted: Fri Jul 02, 2004 6:18 am
that will be a good choice for the sound and not to bad on the videocard
been looking at that card what is your opinion on it?
PostPosted: Fri Jul 02, 2004 6:37 am
I really dont have too many complaints with it. It has run everything I have thrown at it. I also got 6770 on 3dsysmark03 and like 18500 on sysmark01. Im still anxious to see how it will Handle Doom3 and Half-life 2.
This is my First CPU(well, not really, I did have a Dell, P2 450Mhz for like 5 yrs, but that was my dads, this is mine, I built it). I am still new to overclockin Mobos and videocards, but would like to get into it. Actually, that is the reason I got the IC7-max3, I was told you could overclok the hell out of it.
PostPosted: Fri Jul 02, 2004 9:49 am
Celeron
Celeron
that would be PC, not CPU... CPU = central processing unit, PC= personal computer ( i think?). sorry, i just had to correct you... my stupid teacher asked "name 5 things in a CPU"... ah nvm.
if you want to get into oc'ing, read all the things people have to say about it. doing it safely and carefully is one of the first things you should learn.[/b]
PostPosted: Fri Jul 02, 2004 1:19 pm
BANNED
BANNED
3.2 Ghz 800mhz FSB
Abit IC7-max3 mobo
480watt PS
1gb ddr ram, 400mhz
cd rom
dvd burner
peace
WOW
PostPosted: Fri Jul 02, 2004 4:13 pm
Not bad, not bad at all. The guys are right though, overclock that!! Just be careful, I know 3 kids who ruined their processors by overclocking them too far. Make sure you know what you're doing.
PostPosted: Sat Jul 03, 2004 2:20 pm
Location: Kicking the crap out of the people who lied to me about using Folding@Home and those who declined!!
That computer is very good, but what's your price range? I think you should get a Monarch Computer. You can get it for about $2,200. You can also get a P4 3.4 for about the same amount. The one I'm going to get is about that much:
AMD Athlon 64 3400
MSI K8N NEO-Platinum nForce3 250 Gb Audio/LAN/USB/IEEE/SATA/DDR-400/ATX
a kind of cheap tower though.
PS: 520W
memory: 1gig of OCZ
Maxtor 160 gigs
dont want a cd burner
nVidia GeForce 6800 Ultra 256 mb
Modems.....operating system.....etc...... thats w/o the monitor printer etc.
PostPosted: Sat Jul 03, 2004 2:42 pm
3.2 Ghz 800mhz FSB
Abit IC7-max3 mobo
480watt PS
1gb ddr ram, 400mhz
cd rom
dvd burner
peace
good to go, with no problems...might want to add another 120 HDD and go with raid if money permits
