It is currently Mon Mar 30, 2015 12:06 am
 Post subject: question about XP disc
PostPosted: Wed Jun 30, 2004 10:06 am
I have purchased a copy of windows xp disc from my school. It is not an OEM disc and has all those fancy anti-piracy stuff on the label side of the disc. However, the disc does say "illegal without a separate license".
what does this license term mean? If I go to a store and buy a $199 copy, does it say the samething on the disc?
This also brings up my next question. I have installed windows xp on my machine. then something happened one time and I was forced to wipe out the disk and reinstall it. I heard the rumor that an XP disc can only be used twice. Is this true? so if I wipe out the computer again, I must purchase another disc??? that's retarded, isnt it?
 Post subject: Re: question about XP disc
PostPosted: Wed Jun 30, 2004 10:18 am
I'd rather be modding!
You got an MDA or MDL or MCL what ever its called version (I can't 'member). I have one as well. I don't know why it says the license thing - mine came straight from MS and I only got the disks and numbers.
The version you have can only be TRANSFERRED once (noramlly its twice I think). This is not the same as loading it or using it. I have used mine twice already and I use XP Corpraite at work - the same disk all the time. Works fine.
Transfer means giving it to someone else.
So its fine - you have a full version and its legit - you just can't sell it.
Manta
PostPosted: Wed Jun 30, 2004 10:42 am
hi Manta,
thank you for the information. My disc also has a license key in the back.
the interesting thing is that when I bought my computer, it came with OEM windows xp home, so it has its own license key. When I installed xp pro, I tried to enter the license key for home edition, and it did not work.
so if i need to wipe out my computer again, the xp disc should not give me any problems, right? I can still install it and then activate it, right?
PostPosted: Wed Jun 30, 2004 11:30 am
emanresu wrote:
hi Manta,
As long as you use the XP disc to do the "wipe out" you should be fine. Its possible that the XP pro disk you have is upgrade only - so you *might* have to install the OEM version and then the Pro version - but I doubt it.
For home (OEM) use the OEM #
For Pro - use the number MS gave you.
WOrse case, you may have an activation problem - you have 30days to call MS and clear it up with them when this happens (they are normally very nice about it). Normally they will just give you a code or something once you explain yourself. If you have a reciept of some type - save it. One problem you could have in the future is if you change machines. and try to install XP there - it may not let you activate - uninstalling it from one machine and transferring it to another may count as a "transfer" - I really don't know. If it is, you can only do it once with your license - and they *might* want proof you bought it. I doubt that as well - but its possible.
have fun
Manta
Unlike other academic licenses, once you are out of school, you can continue to use the OS (assuming you have what I have) legally.
PostPosted: Wed Jun 30, 2004 11:36 am
hi Manta,
the pro disc I have is a full-installation one, so that is not a problem there.
If I get another computer, I will just buy another copy because it is only 10 bucks.
thanks for the info
PostPosted: Wed Jun 30, 2004 11:57 am
emanresu wrote:
hi Manta,
thanks for the info
Check with your school - mine keeps track of names and will only let you buy one.
Have fun
talk to ya later
Manta
PostPosted: Wed Jun 30, 2004 3:15 pm
emanresu wrote:
hi Manta,
thanks for the info
As long as you only use that copy of XP Pro on one PC at a time(ie you dont try to install it on two working computers at the same time), then you can use the same copy on a new PC. Just be sure to wipe the old HDD if you sell it so that you dont have to worry about your CD Key being active on two computers.
PostPosted: Thu Jul 01, 2004 9:59 am
hi Manta, and SomeGuy,
thank you both for contributing. I guess for now I will just live with what I have. It will be at least a couple of years before I get another computer.
the license thing is getting overly complicated...
PostPosted: Thu Jul 01, 2004 10:26 am
i wouldnt worry about it
PostPosted: Thu Jul 01, 2004 11:58 am
worry about what? the licensing?
PostPosted: Thu Jul 01, 2004 12:18 pm
Its not really that complicated.
One license = one instance of the app installed, but you are allowed to transfer to a different machine if you no longer run the old one.
PostPosted: Thu Jul 01, 2004 12:25 pm
since you mentioned the word "instance" some strange thoughts just came up...
can I do this:
partition the hard drive so it will have three partitions, two for boot and one for data.
install the same windows XP on both boot partition, so that if one failed (like be infected by a virus), i can boot using another?
will this be feasible? but is it legal to do?
