It is currently Thu Mar 05, 2015 8:27 pm
 Post subject: Dialogue box on start-up of PC, and then folding quits
PostPosted: Thu Jan 12, 2006 4:01 pm
Location: Washington State, USA - Folding as dustin_wielenga
This is what my shortcut looks like to FAH.
"F:\Program Files\Folding@Home\winFAH.exe" -advmethods -forceSSE
When I restart my computer, I get a messege from FAH explaining how to correctly use the parameters. It lists the usage, and then the options. It doesn't really say what I've done wrong. I click OK, and the folding icon doesn't show up on the sys tray, and not in Task Manager procceses either.
I have an Athlon XP 3000+ and am running XP Home and FAH 5.03.
Thanks for any help folks.
PostPosted: Thu Jan 12, 2006 4:10 pm
You need to replace -forceSSE with -forceasm
PostPosted: Thu Jan 12, 2006 4:39 pm
Thanks, I did what you suggested, restarted, and no more problems. Thanks again!
PostPosted: Thu Jan 12, 2006 7:46 pm
Team Dino
Team Dino
My machine, on the other hand, starts and hangs at the info about gromacs. It's using 100% CPU but it wont show any progress.
PostPosted: Fri Jan 13, 2006 6:17 am
Beta Tester
Beta Tester
Location: I don't suffer from insanity... I enjoy every minute of it
even after several hours? best tp take off ALL flags to see if there may be a conflict with say forseasm...
PostPosted: Fri Jan 13, 2006 12:14 pm
Team Dino
Team Dino
Its been like that for a day, without any flags. Should I redownload the client?
PostPosted: Fri Jan 13, 2006 5:28 pm
Beta Tester
Beta Tester
i would just restart the computer.. if it does it again, try another client like 5.02 or 5.04... ESPECIALLY if you're using the GUI...
PostPosted: Fri Jan 13, 2006 5:30 pm
Team Dino
Team Dino
I restarted it did the same thing. It was running 5.04 linux and i just reinstalled and its working now.
