It is currently Sun Mar 29, 2015 5:39 pm
 Post subject: Connecting 2 computers: Hub or Firewire?
PostPosted: Thu Sep 02, 2004 6:16 am
I'm building a new computer and I'd like to know what is better, using a hub or connecting them through a firewire cable?
I have a Linksys 5 port 0/100mbits hub. I have cable DSL with 3Mbits download and 384Kb upload.
Is is better to buy another cable modem and connect it directly to the other computer? or a router?.
PostPosted: Thu Sep 02, 2004 6:21 am
I would just use the hub. Why fork out more money for the cable modem. I find that there is not usally a speed issue with two or more computer on at the same time
 Post subject: Re: Connecting 2 computers: Hub or Firewire?
PostPosted: Thu Sep 02, 2004 6:42 am
You're better off with a router. Not knowing what your ISP provides you you may have issues with any of the other solutions. I don't know that you would be able to use two modems at the same time for the same account, or if you are allowed more than one IP address.
If you are looking to share your internet connection a router is the way to go.
PostPosted: Thu Sep 02, 2004 6:56 am
Well, I don't have to log in, so I don't know if I will have account issues, but yes, I want to use the internet in both computers.
PostPosted: Thu Sep 02, 2004 7:19 am
There is something called network address translation. It allows your router to share 1 ip with multiple machines. Just plug you computers into the router/switch.
PostPosted: Sun Sep 05, 2004 7:37 am
I tried to use the hub and they ISP blocks my modem and they have to reset it, do you know how to do it?
I''d get the router. Maybe a wireless one. Do the ISP nkow if I have a router? Yes, they charge for multiple connections
Thx
PostPosted: Thu Sep 16, 2004 5:48 pm
you need a router. You're still using multiple IPs with the hub, which doesn't have NAT.
PostPosted: Thu Sep 16, 2004 7:18 pm
Get a wireless router and a coupler 802.11g cards. No wires, little hassle. Besides you'll have a 54mbps connection between computers which is more than enough anyway.
PostPosted: Thu Sep 16, 2004 7:29 pm
I got a netgear 108Mbits. It works fine. The only problem is that sometimes I lose the internet connection, but I don't know if it's beucase of my ISP or the router. I noticed that ftp is running, but no http, so I think it's my ISP.
PostPosted: Fri Sep 17, 2004 7:49 am
there is much confusion on this thread.
i dont know of any DSL that is 3Mbps/384Kbps, so i'll assume you have cable.
2 cable modems will not work unless you have 2 accounts.
a hub will not help you share your cable access.
get a router.
PostPosted: Fri Sep 17, 2004 7:53 am
agree with cigarette, i have a coable modem of 10Mps, and i use a router to connect with my pc and my other machine, and i share internet along with being able to shift data throughout my network......better yet, with a router, u can get some LAN action going:P
PostPosted: Fri Sep 17, 2004 12:57 pm
But you don't NEED a hub/router/whatever. It's recommended, but try a simple LAN cable with a "crossover". Then you just plug it in and set up a network and internet sharing.
When going straight from one PC to the other using NIC's, you'll need the word "crossover" on the packaging. They are available most anywhere. I saw a Belkin cable at CompUSA for about $17.
A router is the more professional choice, but there's nothing saying that you can't just skip all that and use a very common cable.
PostPosted: Fri Sep 17, 2004 1:14 pm
wouldn't he need an extra NIC for that setup?
PostPosted: Fri Sep 17, 2004 1:54 pm
Yup... Did I miss that? I am just assuming that if he has a hub, that at least one NIC is around the house. Most boards at least have a built in hub, so...
Ya, if there's no NIC laying around, disregard.
PostPosted: Fri Sep 17, 2004 2:04 pm
I got the router. I have a crossover cable, but you need 2 NICs, you can achieve the same thing with firewire, but i have to use internet sharing.
Somebody mention that a router will work better, because it's faster, has NAT and you don't need to have both computers on, to use the internet connection.
I got a wireless router, but I'm not using the wireless right now, and it works fine.
thanks for the advice
PostPosted: Fri Sep 17, 2004 4:57 pm
I've never tried 'Internet Sharing' with a x-over...I assume the PC physcially connected to the cable modem would have to be left on for the second PC to be able to still access the Inet..correct?
A decent router is only $40...
PostPosted: Fri Sep 17, 2004 7:01 pm
Yup...and a decent 10/100 NIC is about $5.
There'll have to be a gateway PC that's connected to the internet to be running in order use the connection. It's pretty burdened down as Windows runs it and not hardware.
I brought this up because I saw "need" too much. It's a very cheap networking option for under $20.
