It is currently Sat Apr 25, 2015 1:33 am
 Post subject: Shuttle MN31N.
PostPosted: Thu Aug 26, 2004 4:19 pm
I was going to see if anybody out there has some tweak suggestions for this mobo. I had suggetions for the K7s5A mobo and homemade BIOS's due to the fact of having it for a long time.. however this one is newer to me.
Here is my specs:
-Shuttle MN31N motherboard - Dual channel
-Crucial PC2700 RAM (2x256) 333FSB.
-AMD XP2500 - Overclocked to 2.14Ghz
-NVIDIA eVGA 6800GT 256MB RAM DDR3. @ 380 x 1.10Ghz
-420W ThermalTake PSU
-ThermalTake SilentBoost HFS - lapped- with ASV
I curently run 300Mhz over stock, with an idle temp of 39-40c.
Obvioulsy, if I would have got faster RAM - that would allow a larger buffer.
When I boot, it reads "XP3200+ ... Memory timings 322Mhz".
Settings:
Im happy at this level and everything is supper stable. Just seeing if any other MN31N have other suggestions or anybody..
Balistix will be next down the road.
PostPosted: Fri Aug 27, 2004 5:40 am
i dont understand the deal with FSB. how is it calculated with the ram and cpu. thats the only thing i dont understand from the screenshot.
PostPosted: Fri Aug 27, 2004 6:48 am
Default should be 166Mhz. 166x2 = 333FSB.
However I bumped the CPU and RAM to run at 194x2. = 388FSB.
I think that once you start OC'n, the system can be confused on timings...
However when I go into XP and hit "winkey" + "pause/break" - it shows XP3200 @ 2.13Ghz.
PostPosted: Fri Aug 27, 2004 8:37 pm
so with FSB on cpus you just double the what the bios says to figure your total FSB? is this the same with RAM?
PostPosted: Fri Aug 27, 2004 8:50 pm
Contributing Writer
Contributing Writer
On that XP chip, yes. The frontside bus is double pumped.
If dealing with a P4C (Northwood) chip, you would quadruple it, as the fsb is quad pumped.
PostPosted: Fri Aug 27, 2004 9:25 pm
even better because i run a NW chip in system. now that i think of it in Sandra it did say like 200 x 4 or something like. thanks for the reply
