It is currently Fri Apr 17, 2015 8:41 pm
Post new topic Reply to topic  [ 19 posts ]
 Post subject: Crucial Ballistix
PostPosted: Tue Aug 24, 2004 3:37 am
Professional Dork
Professional Dork
This is good stuff.
I'm currently running PC4000 (DDR500) at 275 at stock settings and voltage. NO Windows flakiness reported or anything. This means my 2.4C is sitting at 3.3. I'm looking right now at getting it to 3.4 and higher.
Oh yeah. The old Seoul Special DDR400 that I had in there would only do 260 FSB and that was at 3/2, timings set all the way down with 2.9 vDDR. Crap.
Ballistix = :thumbsup: :thumbsup:
PostPosted: Tue Aug 24, 2004 5:34 am
Contributing Writer
Contributing Writer
That's awesome. I'm eager to get my hands on some and give it a whirl myself.
PostPosted: Tue Aug 24, 2004 8:17 am
Thanks for the info. Been thinking of these ballistix sticks. I have always used crucial for non-oc machines as the value has always been proven. I am just glad they are doing hand selected primo series sticks now. This may move me away from HyperX and Mushkin.
 Post subject: Re: Crucial Ballistix
PostPosted: Wed Aug 25, 2004 5:28 pm
HK-47 wrote:
This is good stuff.
What is your CPU to memory ratio? If your running that high 1:1, that is awesome! I was able to get my previous 2.4C all the way up to 280 but using the 5:4 ratio on the Abit Max 3 board with older Corsair XMS PC3500.
PostPosted: Wed Aug 25, 2004 7:24 pm
Professional Dork
Professional Dork
Running at 1:1 right now. I think this memory can do a bit more.
PostPosted: Wed Aug 25, 2004 7:31 pm
Nice!
But from what i've read, Curcial XMS memory at PC4000 or higher has done the same...I guess it comes dowb to how low your timings are and how much you pay for the memory.
 Post subject: I picked up a gig based on these tests
PostPosted: Wed Sep 01, 2004 11:07 am
http://www.anandtech.com/memory/showdoc.aspx?i=2145&p=9
8)
PostPosted: Wed Sep 01, 2004 8:04 pm
Celeron
Celeron
WOW, those are some nice a$s results.
PostPosted: Fri Sep 03, 2004 7:39 pm
Very nice!
I just went to the Crucial/Ballistix website, and found out my mobo supports DDR PC4000.
I think I found the ram i'm gonna upgrade too!
PostPosted: Fri Sep 03, 2004 7:46 pm
Celeron
Celeron
DDR4000? DDR400 8)
unless you're going to overclock, then the ram would be [almost] pointless to upgrade to.
PostPosted: Fri Sep 03, 2004 9:57 pm
I editing my n00b mistake, and yes, i'm planing on overclocking my Athlon XP 2100+ on a Abit KD7A mobo.
PostPosted: Fri Sep 03, 2004 10:25 pm
Celeron
Celeron
you dont need fancy high end ram for your 2100+. im sure that the proc runs on a 133 fsb, and even "value" pc-3200 (DDR400) ram is more than enough for that proc.
Check it out.
PostPosted: Sat Sep 04, 2004 8:59 am
Mushkin is good as well.
However Ballistix ownz. Living 3 miles from them rulz as well. Knowing people on the inside is even better.. Not very many PC parts can give me that "special fealing"... this one does.
Buy your Ballisix Here
MUAHAHA, ALL your Ballisix are belong to ME!! HAHAHA
ok im done..
PostPosted: Sat Sep 04, 2004 2:19 pm
Check it out.
Yes it does run on a 133 fsb.
I am more than happy to save some cash! But will that ram be more than adequate to oc my fsb? Say 160 or even (maybe) 200?
You guys definitely know what your talking about, so i'll trust ya.
PostPosted: Sat Sep 04, 2004 4:16 pm
Contributing Writer
Contributing Writer
Which RAM you should get depends on what your upgrading habits are like. I'll agree that anything above name brand PC3200 is a waste on that proc, and I wouldn't both with enthusiast PC3200 either. If you intend to upgrade in the near to moderate future, however, then you'd be wise to buy RAM that can make the transition.
If you do stick with Ballistix, I learned a little tidbit just a few minutes ago when I was answering a different thread. There is surprisingly little difference in their pricing between PC3200 and PC4000 - $138 compared to $144 on the 512mb modules. If going Ballistix, I can't justify NOT using PC4000.
PostPosted: Sat Sep 04, 2004 6:47 pm
Celeron
Celeron
well, theres a [big] chance that you can overclock to PC-4000 speeds.
other than that, yes, what you said makes lots of sense.
PostPosted: Sat Sep 04, 2004 7:07 pm
Contributing Writer
Contributing Writer
?? Am I misunderstand, or are you saying there's a chance a 2100+ would OC to PC4000 (DDR500)? That'd be taking it from 1.73GHz to 3.25GHz! That'd be what, a 5000+? :wink:
What I'm saying is that unless he plans on upgrading his platform, then he'll never utilize PC4000. However, given the price difference between the two (PC3200 vs PC4000), he might as well get it anyway. If nothing else, he'll have a higher resale value down the line.
PostPosted: Sat Sep 04, 2004 10:47 pm
well, after reading another thread, I would like to upgrade to a 2500+ Barton. It seems the most economically viable upgrade solution when it comes to oc'ing. So it would seem to make the most sense in buying the Ballistix memory.
Also from what iv'e read I have a preety decent mobo for oc'ing, so the 2500+ Barton should do rather nicely.
what do you guys think?
PostPosted: Sat Sep 04, 2004 11:32 pm
Celeron
Celeron
That's what i meant when i said "other than that, yes, what you said makes lots of sense." sorry if i sounded a little sarcastic.
seems a little pointless to upgrade to barton when theres newcastle...
but... look at this.
KD7A compat tests
do a little more research to see if 2500+'s can get up to 3200+ on your mobo. if so, then great!
i still think ballistix is too much for it, pretty much overkill for any Athy XP.
