It is currently Thu Feb 26, 2015 8:49 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Aug 19, 2004 8:32 am
Bitchin' Fast 3D Z8000*
DJSPIN80 wrote:
Gadget wrote:
DJSPIN80 wrote:
So when are we going to see the nominations? Best do it now, I'm not known for my patience. :P
I went to the chatroom to see about having dudex do them.... he's not there. Maybe you should do them.... you could do a runner up and a winner for each category that seems appropriate.
:lol: But I'd win every category, even the bad ones!!! ;)
Sure, why not, give me a day or two to look at the code once more.
EDIT: I'd have to decline actually, I like to judge things fairly hence I might insert some of my own bias towards my code. I'll try the maxPC chat and see if I can find Dude-X.
It dawned on me late last night that I was writing to you and not Jipstyle.... :)
I'll find Dudex today - see if he can do it.
 Post subject: And now the awards...
PostPosted: Mon Aug 23, 2004 9:10 pm
I judge you GUILTY!
I judge you GUILTY!
Best Readability: Code Poet
Mantabase
Most Concise
Mantabase - Python
Most Unique Language
Dargon - Visual FoxPro
Some comments:
I can't rate the speed of the programs since I don't have a reliable way to bench these little snippets of code. So the speed categories will not be awarded. Anyhow these programs should run sufficiently fast on any modern PC.
I will provide my opinion of everyone's code here:
DaBrain - PHP
I like this code a lot, it's pretty clean and readable. However, PHP isn't a systems level programming language. Your implementation of the above rules is pretty accurarte as far as I understand how regex works.
Dargon - Visaul FoxPro
I have to say that the syntax of VFP is pretty ugly. But as far as I can decipher, your program seems to implement the rules correctly. Very interesting nevertheless.
DJSpin - C#
I find it unusual to make each rule it's own function. The code looks correct, but I find that style rather ugly. However, I would give points that you used descriptive function names. It helps in the readability department. My approach would have been similar to Gadget's code.
Mantabase - Python
I really like the Python implementation. However, your code does not follow some of the rules correctly for other cases. I am impressed with how Python makes annoying tasks a lot easier though.
Gadget - Java
Your code looks pretty good. I think if I were to write it in C++ using the STL, it would look somewhat similar to this. I will try this later though.
 Post subject: Re: And now the awards...
PostPosted: Tue Aug 24, 2004 4:50 am
I'd rather be modding!
[quote="Dude-X"][/quote]
Wow, Are you sure??
Sorry if I sound a bit in disbelief.
Thanx Dude-x and everyone
Manta *wonders if there has been a mistake*
PostPosted: Tue Aug 24, 2004 11:47 am
There might be a bit of Python bias going on here.... :)
I think your submission is certainly deserving of a most readable award. I believe that mine starts out better, but it gets a bit uglier at the end. Because of the php syntax, Brain's submission isn't the easiest on the eyes, but it was probably the most writable - you can see how the replace methods that use regex to both match and replace are very powerful.
I'm not sure what criteria Dudex used to award the most concise implementation, but I would have probably made that a co-winner between Brain and myself. Brain's solution is 1 loc shorter, but he failed to remove some loc that are close to redundant. I try to base loc off of loc the person has to think about and write. For example, most Java IDE's will fill in the following when you create a new file....
class Filename {
  public Filename() {
  public static void main (String args[]) {
... so I don't count these lines in my concise evaluation. The same for main's in most languages because even if you do write it, you don't actually have to stop and think about it so it only takes a few seconds to type, which is insignificant compared to the amount of time it takes to think about and solve a problem.
I am pretty swamped right now, but when I get a chance, I'll post a Groovy submission.
PostPosted: Tue Aug 24, 2004 1:43 pm
[quote="Gadget"][/quote]
Well, I guess $20 goes further than it used too :)
Manta
PostPosted: Thu Aug 26, 2004 1:58 am
What's up with the broken bbcodes lately?
PostPosted: Thu Aug 26, 2004 5:56 am
Could be something as simple as a typo. All that is missing is the / in the ending tag. BBCode is so similar to HTML I find it simple.
PostPosted: Thu Aug 26, 2004 8:50 am
Typos - I am typing at speed of light - This week is killing me so I mess up - and then don't edit. Next week will be better (I hope)
Manta
PostPosted: Thu Aug 26, 2004 2:34 pm
Manta
Grab the BBCode extension for FireFox - works great!
PostPosted: Thu Aug 26, 2004 2:54 pm
That's a good math/physics problem: If someone types at the speed of light, how many words per nanosecond does this amount to? :)
PostPosted: Thu Aug 26, 2004 5:43 pm
There may be some relativity issues involved. Like everyones relatively slow links
Manta
