It is currently Sat Jan 31, 2015 2:17 am
 Post subject: Simple Flash calendar?
PostPosted: Sun Aug 22, 2004 2:23 pm
How can I make a simple calendar in Flash that highlights the box for the current date? Thanks.
PostPosted: Mon Aug 23, 2004 12:45 am
Chief Surgeon
Chief Surgeon
TsunamiZ, I'm going to move this into Programmer's Paradise, since it would be more appropriate there.
SuperChip64
Forum Moderator
PostPosted: Mon Aug 23, 2004 10:07 am
Would you like the entire code posted here for you, TsumaniZ, or are you just looking for hints?
PostPosted: Mon Aug 23, 2004 6:31 pm
I'm looking for a tutorial if possible. Thanks.
PostPosted: Tue Aug 24, 2004 11:48 am
Bitchin' Fast 3D Z8000*
There are excellent Flash tutorials at http://www.macromedia.com/devnet/mx/flash/
PostPosted: Tue Aug 24, 2004 12:26 pm
I don't have DevNet, though. :(
PostPosted: Thu Aug 26, 2004 1:56 am
Have you tried ACM?
PostPosted: Thu Aug 26, 2004 12:28 pm
Gadget wrote:
Have you tried ACM?
What's do I do with that?
PostPosted: Thu Aug 26, 2004 2:29 pm
TsunamiZ wrote:
Gadget wrote:
Have you tried ACM?
Look under professional development centre.
