It is currently Sun Apr 26, 2015 10:16 pm
 Post subject: How to create a batch file?
PostPosted: Fri Aug 20, 2004 11:21 am
I want to create a batch file to do what is posted on this web site "http://texturizer.net/firefox/tips.html#oth_usb" but I have never created a batch file and need help in how to create one thanks.
 Post subject: Re: How to create a batch file?
PostPosted: Fri Aug 20, 2004 11:34 am
I'd rather be modding!
Open notepad.
Put the line in that they tell you
Save the files as Firefox.bat
you are done.
Now, when you want to launch FF from a USB key you goto the key and click on the batchfile (not firefox.exe).
Now FF will open with your profile ready.
FireManta
PostPosted: Fri Aug 20, 2004 1:12 pm
thanks
PostPosted: Fri Aug 20, 2004 3:07 pm
forest3292 wrote:
thanks
No problem. If you have trouble getting the file to launch FF right, come back and I will revise the instructions to make them more clear (they need a bit of help really).
MantaFox
PostPosted: Tue Aug 24, 2004 2:54 pm
Bitchin' Fast 3D Z8000*
Shouldn't that be FireBase and MantaFox instead? :)
PostPosted: Tue Aug 24, 2004 5:30 pm
Naw, "Manta" is dynamic. :)
Manta
