It is currently Tue Jan 27, 2015 3:07 am
 Post subject: Any networking gurus out there?
PostPosted: Tue Jun 29, 2004 10:07 am
Kay here's the deal. I'm trying to network two machines together in the same room, both running XPpro, both recently formatted. I've been fighting with this all night and the closest I get to either PC seeing eachother, is in the Folders Tree under My Network Places/Microsoft Windows Network/MsHome (which I left as the default workgroup name), I can see both PC's (represented my their names). This is true on both machines. HOWEVER, when I try to access the files from the other PC I get an error which says:
"\\'~name of machine trying to access~' is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions. The network path was not found."
I've gone as far as to allow sharing of the entire C: drive of both machines. I've ran the networking wizard numerous times first on the Host then the Client machine, restarting after each.
The host machine (A7N8X Deluxe rev 1.4)connects directly to the internet through the NIVIDIA nForce MCP Networking Controller. A Crossover cable is used to connect the other controller, the 3Com EMB Fast Ethernet Controller, to a Netgear FA311 NIC on the client.
Not sure what more information to give so if anything else helps, post what you need to know and I'll get back soon. I'll be checking this thread periodically today.
Thanks!!!
PostPosted: Tue Jun 29, 2004 11:39 am
im not really a networking guru myself but did you see if the ICS option is enabled? ICS = internet connection sharing. do you have any firewalls installed on both machines?
PostPosted: Tue Jun 29, 2004 5:06 pm
Do you have a firewall installed? Make sure the LAN is set to be in the trusted zone.
Also to make things simple, make sure you have a user name and password that is identicle on both PCs.
PostPosted: Tue Jun 29, 2004 5:11 pm
Can you hit them by IP??
as you should also be able to do a \\192.x.x.x to get to that machine.
 Post subject: Man I feel lame....
PostPosted: Tue Jun 29, 2004 6:20 pm
It was Zone Alarm this whole time....
AAAArrrrggghh!!!
I disabled it for a bit to see if I could get results and sure enough, Network lovin for all.
Still can't connect to the Internet from the client pc though.
Someone mentioned ICS.... I'm pretty sure I ran into that sometime lastnight. Not sure I can remember where it's at to see if for sure I enabled it.
PostPosted: Tue Jun 29, 2004 10:00 pm
Yeah that used to get me all the time (the firewall).
 Post subject: Re: Man I feel lame....
PostPosted: Tue Jun 29, 2004 10:17 pm
AAAArrrrggghh!!!
bridge the connections in order to share the internet to the other comp. its as easy as holding control to select both network adapter and right clicking on one and going to bridge. make sure your client is set up to recieve an IP on its own
