It is currently Fri Feb 27, 2015 4:57 pm
 Post subject: HSF recommendation
PostPosted: Tue Aug 10, 2004 6:09 pm
this xmas when i get a new computer, i want to get an after party HSF for the mild to moderate overclocking of an P4 2.4C. i getting a buget PC tho, so i would prefer if the HSF cost no more than $22. any ideas and supporting reviews would be appreciated.
PostPosted: Tue Aug 10, 2004 7:21 pm
Try this one. It will run a few bucks more though. You should be able to get it for around $35. I've used this one myself and it is great for moderate overclocking. I ran my 2.6P4 400mhz clear up to 3.02 with no problems.
http://www.thermaltake.com/coolers/spark/a1715.htm
PostPosted: Tue Aug 10, 2004 11:13 pm
zalman cu 7000
PostPosted: Wed Aug 11, 2004 3:48 am
BiggPa wrote:
zalman cu 7000
Good one, and good price. 7000A is $39
The upgrade to this is the 7000A Cu for $10 more.
But maintaining a strict budget, the Thermaltake Spark 5 runs right at $22.
PostPosted: Wed Aug 11, 2004 5:45 am
Contributing Writer
Contributing Writer
Let's hack that $49 price tag... Trust me in that eWiz is reliable (I've used them several times, including my hsf) and you can get the 7000a-cu for $35.87 shipped when going through pricewatch:
CNPS7000a-cu
And I realize the original poster doesn't want to spend more than $22...I'm posting the above link because it's very handy when recommending the 7000a-cu in other threads, as it's the lowest price I've been able to dig up from a reliable vendor, and by a nice chunk of change as well.
PostPosted: Thu Aug 12, 2004 10:51 am
One4yu2c - thanx for the link, ewiz.com has great deals. if i get the P4 2.4C, i can get the CNPS7000-CU for $29.50. altho my pc is supposed to be cheap, i figured id get the zalman neways. wish me luck when i try to overclock. also does neone know of any issue between the zalman and the Asus P4R800-V Deluxe? the zalman site doesnt list ne but i just wanna b safe
PostPosted: Thu Aug 12, 2004 12:27 pm
Contributing Writer
Contributing Writer
You should look at my appraisal thread if you're interested in a 2.4C that's passed overclocking tests...
PostPosted: Thu Aug 12, 2004 7:04 pm
You should be OK if your motherboard is not on Zalman's list. I have a CNPS7000A-Cu on a Asus P4C800-E Deluxe board and it fits perfectly. I have my 3.2C running @ 3.6Ghz(could go higher but no real need to) with temps 38C(idle), 49C(Max). GREAT HEATSINK!
PostPosted: Mon Aug 16, 2004 3:16 pm
since im deciding to overclock, would i need a fan or nething for the NB? i heard NBs with integrated graphics get hot. theMB just has a bare heatsink on it, i was thinkin about gettin this 40mm fan and wut about my memory, im thinkin of gettin a pair of vantec copper heatsinks for them
PostPosted: Mon Aug 16, 2004 8:37 pm
CNPS7000a-cu
Ah poo! Why pay less when you can pay more!? Very odd logic you have there...very twisted.
Lol..I just keep Frozen CPU as a quick link as they carry just about everything outside of main hardware. I just give it a quick look through and link to them. I actually don't think I order much at all from them as much as I link to them. They're generally over priced on the stuff I want.
They had the stacker for $199 while newegg carried it for $154 and free shipping. (and who the hell is Taylor Huckstep??) Then they had the OCZ PowerStream 520 for $156, then newegg beat them with one about $120...free shipping.
I now have another bookmark down for a price comparison though! Thanks:D
PostPosted: Wed Aug 18, 2004 2:53 pm
6800 GT
6800 GT
I went with the Gigabyte 3D cooler pro.
Pretty nice heatsink if you ask me, also comes with mounting brackets for P4, Athlon XP and Athlon 64 so if you change proc's you can keep the HSF.'
Oh it lights up too. =]
PostPosted: Thu Aug 19, 2004 10:13 am
gigabyte 3d coolers offer good performance, but wut about price?
PostPosted: Thu Aug 19, 2004 2:15 pm
6800 GT
6800 GT
Cheaper than Zalmans and thermalrights.
I paid 39.99 for the Gigabyte 3D cooler Pro from Fry's. Newegg wanted 45.99. And like I said, fits XP's, 64's and P4's.
PostPosted: Thu Aug 19, 2004 8:06 pm
CNPS7000a-cu
