It is currently Fri Mar 06, 2015 1:29 am
 Post subject: LAN
PostPosted: Tue Aug 17, 2004 7:19 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
I dont know much about networking, (come to think of it i dont know much of anything) but how would i go about setting up a lan.
PostPosted: Tue Aug 17, 2004 8:31 pm
ok now, well first you need more than one computer. you need at least two computers with NIC cards in them. then of course you need the cAT 5 cables and a router, switch, or hub whichever you like though i recommend a router if you want to share internet connection between the two computers.
no offense gamefreak but do some research because these kinds of questions are ahhhhhhhh. check out www.dalantech.com and read the articles there.
PostPosted: Tue Aug 17, 2004 8:48 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
i know how to do that but what i am talkin bout is a gaming lan with a server with games on it ect.
PostPosted: Wed Aug 18, 2004 9:01 am
Your question is horribly vague.
The only difference between a LAN and a LAN with a game server on it is .. the game server.
So, if you know how to set up a LAN, do that .. then add a machine that will serve the game you want to play. This depends entirely upon the game.
What is your question, exactly?
PostPosted: Wed Aug 18, 2004 9:04 am
7yrs+11,000 Posts
7yrs+11,000 Posts
sorry, what i am asking is how the other computers access the game server. I think. I am horribly confused right now.
PostPosted: Wed Aug 18, 2004 9:42 am
throught multiplayer options by picking the server you want to play on
PostPosted: Wed Aug 18, 2004 10:39 am
7yrs+11,000 Posts
7yrs+11,000 Posts
I got it, i think, if on linux i set up a file shareing server???
PostPosted: Wed Aug 18, 2004 12:07 pm
You don't NEED Linux to fileshare...Windows will do it jsut fine. But like the otehrs said, your question is presented in an ambiguous manner.
you could simply connect two PC's with an Ethernet roll cable..a-la-LAN.
or connect them through a switch (like others already mentioned).
PostPosted: Wed Aug 18, 2004 12:28 pm
As long as all your computers have IP's that belong to the same broadcast domain, then your computers should be able to ping the game server. That, and gameservers send out multicast/broadcast packets to advertise the game server. So all you need are n PC's using an Ethernet Network (RJ-45, Swtich, and some CAT5 cables). You can configure this one of two ways:
1) Local Only: No internet access.
2) Local with Internet.
The first one means that you can go and buy a cheap switch and cables, hook it up, set the IP's on all the clients to the same broadcast domain, configure the machines so they belong to the same WORKGROUP, and then setup your game server, create a local game, and you're set.
2) This one is a bit complicated, but not so much so. Todays routers, such as the Linksys BEFSR41, also functions as a DHCP server. So all you need to do is to plug in the computers to the switch on the back (maximum 4 PC's since there's only 4 ports) via Cat5 cables. Set the workgroup name to the same thing on all of them (default workgroup name for Windows is WORKGROUP), and start your gameserver. This is similar to the #1, where it's local only. If you want outsiders to game with you, you have to open up the respected ports for your games.
Really, it's not that hard at all. I have my own LAN at home and my friends just come in plug in their laptops and we're game. Same with my friends house too. Oh, and your question was a bit vague, I command you to ask better questions!!!! :twisted:
PostPosted: Wed Aug 18, 2004 12:35 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
i will, thanks
