It is currently Fri Jan 30, 2015 7:06 am
 Post subject: Inspiron 9100-resolution screws up when I put the lid down
PostPosted: Wed Jun 30, 2004 4:57 pm
When I close the laptop so that I can move it or just because I am not going to use it for a while, the screen often changes resolution in the process and then when I open it back up the icons on the desktop are all scrunched to the upper left corner.
Any ideas whats goin on here? Or do I have to re-arrange my icons every time?
PostPosted: Thu Jul 01, 2004 10:30 am
iv never heard of that happening before...what if you put it in suspend, then close it?
PostPosted: Thu Jul 01, 2004 12:16 pm
It does fine then.
It's only a problem if I want to leave a program working that will take a while, so I put the lid down but leave the computer on.
 Post subject: Re: Inspiron 9100-resolution screws up when I put the lid do
PostPosted: Fri Jul 02, 2004 1:14 pm
BANNED
BANNED
WOW
PostPosted: Wed Jul 07, 2004 12:41 pm
King of All Voodoo2 Cards
SomeGuy wrote:
It does fine then.
Go into the power options in the control panel, click on the Advanced tab, go down to where it says "When I close the lid on my portable computer" and set it to "Do Nothing"
PostPosted: Wed Jul 07, 2004 1:16 pm
Flytrap7 wrote:
SomeGuy wrote:
It does fine then.
Thats what I have it set to.
PostPosted: Wed Jul 07, 2004 1:25 pm
The BIOs settings would be the next place to look.
Just look for any options under Power Management.
PostPosted: Wed Jul 07, 2004 1:47 pm
Hmm, Ill check that out.
PostPosted: Wed Jul 07, 2004 1:55 pm
Nothing in there that appears to apply to the problem...
if it helps any, to clarify, the screen returns to its correct resolution, its just that the icons are bunched up as if the resolution was shrunk at some point.
PostPosted: Wed Jul 07, 2004 1:58 pm
Hmmm.....what else..?
Did you just purchase it recently?
Did you check the manufacturer's site for patches that might relate to the problem?
PostPosted: Wed Jul 07, 2004 10:20 pm
Um, we just got it about 2 months ago Id say.
I couldnt really find anything on it from their sight. I might just fire off an email to tech support.
PostPosted: Thu Jul 08, 2004 9:36 am
I would start thinking about either sending it off to tech support or returning it if it has some kind of 90 day return policy
PostPosted: Wed Jul 14, 2004 12:47 am
Are you running Dell Quickset on this box? Is this a Windows machine or Linux?
If windows, I recommend that you download and install the latest Dell Quickset to see if that can solve your problems.
PostPosted: Sun Jul 18, 2004 11:03 pm
I believe that is one of the jazillion apps Dell had preinstalled.
I'll check it and see if there are any options that might relate to that in there.
PostPosted: Sat Aug 14, 2004 9:31 pm
I have the 9100 as well and to let you know the drivers they send are usually way out of date. So I would go download the latest driver. I would recommend going to www.omegadrivers.com and dl their driver. Works great. By the way, if you go try to dl the driver from ATI it wont work.
PostPosted: Tue Aug 17, 2004 1:08 pm
Is it going into standby when you close the lid? It could be an issue coming out of standby mode.
Try and get them to replace the Mobility Radeon 9700 with the 9800 while they're fixing it.
-[Ch]ams
