It is currently Mon May 04, 2015 5:16 am
 Post subject: new hardware found
PostPosted: Tue Aug 17, 2004 12:16 am
Goog Morning
I keep getting this message new hardware found printer unknown but my printer is working fine. How do I stop this ?
Thank You
Ed
PostPosted: Tue Aug 17, 2004 8:06 am
could be the cable or a driver issue. more info is needed for us to help you out. what brand and kind of printer do you have? o/s you using? etc.etc.etc. list your hardware specs too.
PostPosted: Tue Aug 17, 2004 10:20 am
I am running Windows XP a HP printer 990cse I upgraded drivers and this is when everything started. Now I can't even install my old software.
PostPosted: Tue Aug 17, 2004 11:10 am
hmmm.........delete the printer from the device manager if you are using windows, reboot the computer, and let windows re-detect the computer again.
 Post subject: New Hardware Found
PostPosted: Tue Aug 17, 2004 3:41 pm
Hi All
I did a system restore from before I did the upgrade and it is working fine. Thanks for the help. I would say it was HP printer software upgrade that caused my problem. Again Thanks
Ed :lol:
