It is currently Tue Mar 03, 2015 1:32 am
 Post subject: What should i do with $105?
PostPosted: Tue Jun 29, 2004 2:21 pm
i am thinking of either getting another 512mb stick of ram so i can run in dual channel. i am also thinking of grabbing another 160gb maxtor drive so i can run in raid and have 320gb of storge. which would be better?
 Post subject: Re: What should i do with $105?
PostPosted: Tue Jun 29, 2004 3:34 pm
the ram would probably be best for now :)
more ram=less swapfile usage...wOOt!
PostPosted: Tue Jun 29, 2004 3:40 pm
definitely ram is the way to go. or you can always give it to me. lolool just kidding.
PostPosted: Tue Jun 29, 2004 4:20 pm
i found a stick identical to what i have now for $70 after rebates from officemax. the funny thing is i got my other ram about a year ago for $50 after rebates
PostPosted: Tue Jun 29, 2004 4:32 pm
I feel your pain... :cry:
PostPosted: Tue Jun 29, 2004 4:37 pm
yea, i hate how volatile ram prices can be, but at least theyre coming down some, a month or 2 ago the same stick was never under 90 after rebates even
PostPosted: Tue Jun 29, 2004 6:41 pm
check your motherboards manual because i do believe that for dual channel both sticks of memory have to be the same i know when i bought mine the place i got it from noted that to me at the time i had 512 but desided to get the extra 512 while i was there
PostPosted: Tue Jun 29, 2004 10:25 pm
go with RAM
PostPosted: Wed Jun 30, 2004 7:08 pm
well, i got the ram today and its a lot different than the old dimm i have. the memory chips are bga instead of tsop and the chips are made by kingston them selves instead og wionbond. i am wondering if this new ram will work for dual channel?
PostPosted: Wed Jun 30, 2004 7:12 pm
you can send it to the "toidiochysp needs a better video card fund"
my radeon 9000 cant handle it anymore :(
PostPosted: Wed Jun 30, 2004 7:13 pm
sorry, i already bought the ram, and im gonna buy a couple of cds with my left over money.
PostPosted: Fri Jul 02, 2004 6:27 pm
well, the new ram works great. it also works at 192mhz just like the old ram i had so i can oc up to 2209mhz, im happy, except i broke my damn mobo.
 Post subject: what should u do with the dough...
PostPosted: Fri Jul 02, 2004 6:40 pm
BANNED
BANNED
Go call an escort service..and ask them what u can get for a hundred buck. Buy memory later
