It is currently Wed May 22, 2013 8:20 pm
 Post subject: Any C++ IDEs that run on Linux but create *.exe?
PostPosted: Thu Aug 25, 2005 2:41 pm
Max [Ph]otographer
Max [Ph]otographer
Hey all.
I'm taking an introductory course to C++ this fall at my local community college. I was kind of hoping that I could just use Linux to do all my work. (Debian 3.1 Sarge).
Anyway, I installed Anjuta but I couldn't figure out how to create an EXE. I guess it can't be done in Anjunta?
Are there any IDEs that will create EXE's from Linux?
My second option was to WINE one of the IDEs that came with the book. However, both of them failed to install on WINE.
They were:
Microsoft Visual C++ 6.0 Introductory Edition
Borland Visual C++ Builder, v.5
Is there a decent Windows based IDE that runs well on WINE?
Thanks,
Dan O.
 Post subject: Re: Any C++ IDEs that run on Linux but create *.exe?
PostPosted: Thu Aug 25, 2005 2:54 pm
Belboz99 wrote:
Hey all.
They were:
Thanks,
Dan O.
There's Anjuta or KDevelop. However, as far you're problem is concerned, you have to understand the file system of Linux. A file is an executable, a text file, an image file, et al. UNIX/Linux doesn't need file suffixes (*.exe's, *.txt's, et al), instead, it knows the file is an executable because the file in itself is an executable.
If you want to know what the file type is, use the file command:
#file myFile
This should give you an output. Now, if you want to write C++ code in BASH (using nano or your preferred text editor), just use the following command:
#g++ mysource.cpp
This should give you a file titled a.out, however, if you want to specify your own file name, use the following command:
#g++ -o myExecutable mysource.cpp
This should give you an executable file called myExecutable. If you want to run it, just use the ./ format:
#./myExecutable
PostPosted: Thu Aug 25, 2005 8:25 pm
Max [Ph]otographer
Max [Ph]otographer
DJSPIN, I don't think you read my full post.
I know full well that Linux doesn't care what extension (if any) is being used.
The problem is that I need to turn in an *.EXE to my professor at the end of every week. He is going to execute it on a Windows based OS.
Now, is there any IDE that can link my code to Bill Gate's code on Linux?
If there isn't (which I wouldn't be surprised) is there a decent IDE that I can run on WINE to create *.EXE files?
Put simply, I need to compile Windows Executables in a Linux environment.
Thanks,
Dan O.
PostPosted: Thu Aug 25, 2005 8:42 pm
Thanks,
Dan O.
Then just port your code over to Windows and compile it again. It wouldn't matter, when you run the C++ compiler, it produces executable files that run on Linux and not Windows. So just copy/paste your code from Linux to whatever IDE you're using. I have yet to encounter a C++ IDE for Linux that produces Windows *.exe's.
PostPosted: Fri Aug 26, 2005 9:48 am
Well, time for you to learn something new today...
The compiler:
http://www.mingw.org/
and an IDE:
http://visual-mingw.sourceforge.net/
See above post.
Belboz99 wrote:
Hey all.
They were:
Thanks,
Dan O.
PostPosted: Fri Aug 26, 2005 9:54 am
The compiler:
and an IDE:
Did you read what you posted? He's asking for a LINUX C++ IDE that can compile C++ code to a Windows executable. He wants to write code in Linux C++ IDE and have it produce Windows executable.
I didn't need to learn anything, YOU need to learn something new today, the Ming is a WINDOWS port of GCC.
PostPosted: Fri Aug 26, 2005 9:56 am
The compiler:
and an IDE:
BTW, read what I posted, I HAVE YET TO ENCOUNTER A C++ IDE FOR LINUX (i.e., something that runs in Linux) THAT PRODUCES WINDOWS *.EXE's
Read->Comprehend->Think->Post.
PostPosted: Fri Aug 26, 2005 1:59 pm
Million Club - 5 Plus*
sudo apt-get install mingw32
"To build for Windows, simply prefix every command with i586-mingw32msvc-"
Source, and more info: http://rooster.stanford.edu/~ben/linux/crosshowto.php
This is a how-to for C++ compiler for LINUX that produces WINDOWS binaries...
It doesn't have IDE integration, but that's ok...
PostPosted: Fri Aug 26, 2005 2:05 pm
Ha! That's interesting. However, no IDE integration is kind of a bummer. Oh well.
PostPosted: Fri Aug 26, 2005 2:29 pm
I think that it can be made to work... You just have to specify the compiler in the project methinks...
Anyways, don't you test in linux then only make 1 windows exe?
PostPosted: Fri Aug 26, 2005 2:45 pm
Are you serious? Did you bother looking through the site. I've USED minGW and have first hand experience with compiling WINDOWS CODE under a LINUX environment. It compiles windows code UNDER Linux and produces a WIN32 executable. THIS IS EXACTLY WHAT the author of this thread is looking for.
You can download the mingw package. Install it, write a windows program (using the WIN32 API), compile the program, copy the resulting .exe to a windows partition. Reboot into windows, and execute it.
Let me repeat this...I have done this! Many people have done this. It is well known in the compilers community.
Apparently you didn't understand that this mingw works UNDER Linux. It was also ported TO windows, but it's aim is to be a compiler that runs under _Linux_ (as well as other OS) and produce WINDOWS binary executables.
As far as an IDE goes...well...does it matter? Any IDE should do. I coded my Windows program using vim (again...under Linux...Slackware 9.1 to be exact). I'm sure since you think you know it all, you can point him in the direction of IDE's under Linux, I'm sure there are plenty of them.
Once again...you learn something new today.
PostPosted: Fri Aug 26, 2005 5:38 pm
nano is my IDE. The only good gtk+ based IDE is anjuta and it was absolutely horrible. The canvas can't seem to draw itsellf to save it's life.
Anyway, a suggestion for Belboz99:
Never ask if with linux. Always ask how.
Anyway, if you are a kde user, I think kdevelop has a project that lets you create a project template for a windows executable. :\
PostPosted: Wed Aug 31, 2005 10:41 am
nano is not an IDE.... (Integrated Development Enviornment, ?)
Nano cannot compile.... it is just a text editor (a nice one at that)
He would still need a compiler... Which is what mingw would be for
