It is currently Mon Apr 27, 2015 1:22 am
 Post subject: P4P800 Northbridge fan?
PostPosted: Sun Aug 15, 2004 9:17 pm
Any using this board who has come up with a cooling solution for the NB heatsink? It looks like you could just screw a 40mm fan or something similar sized onto the heatsink to help cool it, just wondering if this has worked for anyone?
PostPosted: Sun Aug 15, 2004 9:51 pm
there are many after market NB hsf avaliable
check out the modders list in this forum
PostPosted: Thu Aug 26, 2004 4:12 pm
BANNED
BANNED
Actually, I accidently found a solution. My video card produces quite a bit of heat, but it only has one fan...duh. Well, since that fan is onthe bottom of the card, the top of the card doesn't get any cooling. That's where the AGP Airlift Graphics Card Cooler came in handy. Well, although the little rubber pads help, it doesn't have the clearance under it to move enough air. Well, I "leaned" it up against my Northbridge heatsink, and it now does double duty cooling both my graphics card, AND my Northbridge chipset.
PostPosted: Sat Aug 28, 2004 4:11 pm
interesting concept. is your AGP cooler just propped up against the NB? or is it like secured at all? just thought i would mention it because i did the same thing with a 90 mm fan to the top of my 9800 pro to cool the Ram on it and it ended up messing up something on my card, so i had to get a new one (luckily i tricked ATI into thinking it was defective)
PostPosted: Sat Aug 28, 2004 9:25 pm
BANNED
BANNED
Yeah...it was prior to installing my Thermaltake Giant 3. It was propped up in a way that it wouldn't cause a problem. It comes with little rubber "feet" and weighs about 2 ounces...if that.
