It is currently Mon Mar 02, 2015 11:40 am
 Post subject: Question Question Question chooose A. or B.
PostPosted: Sun Aug 15, 2004 2:25 am
hi i got one more question about my OCing... which do u guys think is better for my OC? A or B
A. 2.3ghz with 191.mhz ram or...
B. 2.2ghz with 220.mhz ram
(stock ram are pc 3200[200mhz stock])
so i gain 20 mhz in ram speed or loose 9mhz and gain 100 mhz cpu speed?
o yeah i am mostly GAME. (doom3)
cpu=athlon 64 3200+ thnx alot in advance
PostPosted: Sun Aug 15, 2004 12:47 pm
-A stock 3200+ is fine for anything. I question your reasoning to OC.
-ratio...check your ratio. I THINK you're running asynch...run synchronous (1:1).
-Can't you eek out 9 more Mhz on "A" ???
-And run a benchmark like Sandra. This should give you a pretty graph to tell you which is better.
PostPosted: Sun Aug 15, 2004 12:50 pm
the thing is i dont know if my motherboard will support it.. the ratio thingy 1:1 5:4 etc... i dont have that any other way i can do that ? or can i OC my cpu a lil more to gain back the 9 mhz?
PostPosted: Sun Aug 15, 2004 12:52 pm
To make up the 9Mhz, ya...try the next jump in FSB. It may or may not work. If you get the 200Mhz FSB back, I'll guess "A".
If you don't have the option for ratio, the that's cool I guess. Can't do anything about it.
PostPosted: Sun Aug 15, 2004 1:57 pm
thnx for replaying i will try sandra and see which is better :)
PostPosted: Fri Aug 20, 2004 8:47 pm
This depends totally on the motherboard used and if it will (can) adjust well to the overhead of better ram (EG overclock well). If you have a good VIA or nVIDA mainboard then get the better ram (EG higher rated your ram). You always want more overhead with ram because you may 'need' it in next system. In other words, when I buy ram I get the best ram I can afford at the time with the highest rated speed...that is fully compatible. You can always manually "sync " your FSB and DRAM easily in the bios with expert settings if it's rated above your FSB chips and you decide to run 1:1 (downclock).
