It is currently Sat Apr 25, 2015 9:00 pm
 Post subject: Peer 2 Peer Question
PostPosted: Thu Jul 01, 2004 3:36 pm
Some time ago, I used Kazaa to file share. Then I realized, like so many others, that it had spyware and made the switch to Kazaa Lite. At least for a while. I haven't used the program in some time - that time lengthened by the fact that I fried my PC and had to rebuild it. Now that I'm looking into downloading Kazaa Lite again, I learn that they are charging for it. Bogus! Does anybody know of a good file share program that is free of both charge and spyware? Or am I stuck with choosing what I believe is the lesser of two evils?
PostPosted: Thu Jul 01, 2004 3:38 pm
stuck....
dont do anything illegal
PostPosted: Thu Jul 01, 2004 4:07 pm
mIRC, BitTorrent, or Direct Connect.
just so u know, these are not as easy to use as Kazaa
 Post subject: God, I love Google!
PostPosted: Sun Jul 04, 2004 4:24 pm
Well, I did a Google search on Kazaa Lite and found a website that has Old Versions of the software. You don't need to pay to use those older versions either. Just download one and use it.
PostPosted: Tue Jul 27, 2004 7:30 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
I used bearshare for quite a while and there so no spyware. I am pretty shure its illegal tho. I would recoment just biting the bullet and buying napster download cards.
 Post subject: Re: God, I love Google!
PostPosted: Wed Jul 28, 2004 4:08 am
That's what I did as well....
PostPosted: Wed Jul 28, 2004 12:02 pm
Astro lube 2 the MAX!
eDonkey client represent!
PostPosted: Thu Aug 12, 2004 8:38 pm
im using DC++.
PostPosted: Fri Aug 13, 2004 5:18 pm
I just went to gamespy'"s http://www.fileplanet.com/ and typed in kazaa lite and d/l it. no cosf. hope that helps :twisted:
PostPosted: Sat Aug 14, 2004 10:41 am
FTP! Works well.
