It is currently Sat Jan 31, 2015 5:40 am
Post new topic Reply to topic  [ 591 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 30  Next
PostPosted: Tue Jul 13, 2004 9:48 pm
T-bred xp 2600+ to 2.4GHZ 210*11.5
PostPosted: Wed Jul 14, 2004 6:35 am
Max [Ph]otographer
Max [Ph]otographer
Geeze, what's your temp on that thing?
If you fold, as you damn well should, what's your foling temps?
Dan O.
PostPosted: Wed Jul 14, 2004 1:07 pm
I had to back it down a bit because my motherboard keeps undervolting on the vcore setting and couldn't keep it stable, so know it's set to 210*11 @ 2315 mhz :-) Idle temp 42c and 47c load with watercooling.
PostPosted: Thu Jul 15, 2004 8:55 am
I can get my Athlon XP 2400+ to hit 2300Mhz smoothly!
PostPosted: Fri Jul 16, 2004 3:56 am
xp-m 2500 @2.5 440 fsb 1.70v
PostPosted: Wed Jul 21, 2004 9:50 am
Sigh. My poor Palomino is so lame, I'm lucky I can overclock it from 1733 to 1820MHz.
PostPosted: Fri Jul 23, 2004 8:13 pm
M-Powered
M-Powered
Refilled my Danfoss compressor with a new R-508b refrigerant and replaced the DC 120mm fan attached to the condenser with a high profile AC industrial fan...
3.2C at 4.58 GHz
2.8C at 4.39 GHz
PostPosted: Fri Jul 23, 2004 11:33 pm
BANNED
BANNED
i have a Intel 3.2 ghz pushed to 5.12 ghz. im using liquid nitrogen for my water cooling kit, dont ask how much i spend on LN... :shock:
PostPosted: Sat Jul 24, 2004 6:22 am
M-Powered
M-Powered
And then you woke up. :roll:
PostPosted: Sun Jul 25, 2004 9:24 am
p4c 3.2ghz OC'd to 3.36ghz 841 mhz fsb. see my post "is air cooling really dead?" for screen shots of the overclock.
 Post subject: My Amazing Chip!
PostPosted: Mon Jul 26, 2004 12:37 pm
I recently put some salsa on my brand new dorito nacho chip, made by nabisco, and now i can run at an incredible three bites a second!!!!! :twisted:
PostPosted: Wed Jul 28, 2004 6:05 pm
I'm attempting to stick with a low latency memory timings (2-2-2-5) and a decent overclock on my 3.4C...so far this amazing new corsair XLL 3200 matched pair memory kit has let me overclock from 200fsb to 225 WITH PAT on my Asus P4C-800E....not bad at all!
PostPosted: Fri Aug 06, 2004 9:56 pm
maxx or does anyone else have pics of their water cooling setup?
i really cant overclock xeons, theres no option for multipliers. plus they run at 46 c and 50 c in closed case, hotter than most cpus, even when overclocked. but before with my p4p 800 i had a 2.4 ghz 533 fsb oc to 2.8
first time i overclocked was a penitum 3 on an abit mobo, which was so easy, because of its multiplier unlocked.
PostPosted: Sat Aug 07, 2004 2:16 am
There's no options to change the mulitplier on the P4P800 either. OC the same way you did with that one.
And I'd hold off on water until you actually need it. If you run into Booradly, he has some good pics of a water system already taken and will probably show you.
PostPosted: Mon Aug 09, 2004 9:57 pm
toidiochysp wrote:
i had a P3 450@540 ^_^
my 2500+ has been up to 2.38Ghz, now its 2.2. damn summer heat. i want winter back
Hey what MOBO do you have and what is the FSB on it?
PostPosted: Tue Aug 10, 2004 5:25 am
3.2C @ 3.6Ghz 225FSB
MSI RX9800 @ 412/365
1024 HyperX PC-3500 DDR434 1:1 2.5-3-3-7
2 x 36.7Gb WD Raptors in RAID 0
3dMark2001SE = 20,494
3dMark03 = 6745
AquaMark3 = 48,472
PostPosted: Tue Aug 10, 2004 2:17 pm
i had it on an Asus A7N8X deluxe rev 2.0, i believe i was running 197x12 i'm currently running @ 2.24Ghz 187x12 i'm gonna try to get to 2.4Ghz this time :D
PostPosted: Thu Aug 12, 2004 2:51 am
Hi fellas! First post here tho i've been browsing this forum for awhile now and have always been an avid Maximum PC reader :)
ok have my athlonxp T-Bred 2600+ run 210 x 11 (2.32GHz) watercooled at 37deg low fan speed and with the 120 cranked up its chillin' at 32deg.
tomjeffy how in the blue hell were u able to hit 210 x 11.5?! dun talk about stability , i can't even get it to post lol
 Post subject: Well??
PostPosted: Sat Aug 14, 2004 6:34 am
P-4 Norhtwood 2.8 Danger Den Silver TDX reported speed by CPU-Z.......
3852
a little over a gig overclock...more than I expected to get
 Post subject: Me Too
PostPosted: Sat Aug 14, 2004 1:13 pm
Location: Defragging brain. Sector 25642401. Percent complete: 01000000%. 64-bit me.
I have also overclocked my PC using nothing more than the FSB, so your little feat is really not all that amazing DEXTER. The specs are on a Athlon XP 1800+ Polimono core, as they are the most overclockable.
Before
Athlon XP 1800+ 1.53GHz
Memory 266MHz (133 Double Pumped)
After overclock
Athlon XP 1900+ 1.62GHz
Memory 288MHz (144 Double Pumped)
[/list][/quote]
Okay, so it's not a big leap, but it does the job.
the_river
