It is currently Tue Apr 28, 2015 8:55 am
 Post subject: Heat problem
PostPosted: Tue Jun 29, 2004 6:04 am
Hello,
Does anyone know of a notebook PC cooler that's reasonably priced that can be shipped to the U.K.?. Have found two coolers over here but one is only suitable for putting onto a desk, the other was (in my humble opinion) not sufficient, none of these were branded. Do Coolermaster or any other cooling companies sell such a device?.
Your comments would be greatly appreciated.
Best Regards,
Tailormadepc.co.uk
PostPosted: Tue Jun 29, 2004 6:11 am
Contributing Writer
Contributing Writer
What were the two you already looked at and didn't have interest in?
Antec makes a cooler, but I can't say how suitable it is for lap use as opposed to being on a desk.
http://tinyurl.com/3f8lw
PostPosted: Tue Jun 29, 2004 6:19 am
Hi,
Both of the one's i'd thought about buying were made of plastic, one was angled with two 80mm x 80mm exposed fans beneath the other was literally three smaller fans built into a flat plastic enclosure, cannot really think how best to describe them other than that. They were approximately $30.00 each and neither seemed to be worth the money (in my opinion), perhaps I just need to shop around.
Shall check out the Antec one though.
Thank you,
Best Regards,
Tailormadepc.co.uk
