It is currently Thu Mar 26, 2015 11:35 pm
 Post subject: Question about Visiontek 9600
PostPosted: Tue Aug 10, 2004 6:17 am
I bought my Visiontek 9600 256mb about 2 months ago and I thought about OC'ing then but didn't really consider it until now. My problem is, the default setting of the VPU core is 325MHz, so says the box. When I open it up in Powerstrip or Rage3d, it shows up as 398MHz. As far as I can remember, I didn't change any of these settings when I first got the card. Now when I try to change the speed back to 325, the lowest Pstrip lets me go is 331. Not sure where I should go from here. Any help would be greatly appreciated. Thanks in advance
PostPosted: Tue Aug 10, 2004 11:34 pm
HAHA!! You're another VERY lucky man!
I have the exact same card!! Don't try to down-clock it. Let me explain.
What both you and me have is a factory screw up.
Our cards were meant to come with the non-pro core (R320 I believe), with a stock speed of 325mhz. Instead, our cards were accidentally built with the 9600PRO core (R350) with a stock speed of 398mhz.
VisionTek TECHNICALLY doesn't even build their 9600 series cards with a pro core at all, so this is obviously pretty confusing.
I've been to the Visiontek forums, and have asked around, and that is what I've been told. you should be very happy, as you have a video card that should've been about $100CAD (I'm in Canada) more then what you paid.
I currently use Omega Drivers and Radlinker to overclock my card, and currently I have it overclocked to 467.31core/365.85mem, though I know I'll be able to go much higher once I get an Amd HSF mounted to the gpu.
Be happy and enjoy what you have man. With stock cooling, you should be able to push your card up to close of what I have and be able to keep it stable.
I've been able to play games like Farcry, UT2K4, Doom 3, and Battlefield:Vietnam for hours, and I've never had a single instabilty issue.
Hope I've shed some light on this. I suggest you register your card, and join visiontek's forums for support and such. There should be other members there that'll be able to give you any other questions you may have about this.
PostPosted: Wed Aug 11, 2004 7:51 am
Hahahaha, that's awesome man. Thanks a lot for the help. Hopefully that's the case. I'll swing by Visiontek's forums. Thanks for looking out
PostPosted: Wed Aug 11, 2004 9:22 am
My bad. I accidentally put 365mhz for the memory. I meant 265.85mhz.
I hate this keyboard.......... :roll:
PostPosted: Wed Aug 11, 2004 3:11 pm
a great tool for oc'ing a radeon is atitool - it automatically will overclock and test the new settings for you. I usually dont trust it completly, but it pushed my 9600xt core up to 615mhz, but i put it down to 600mhz to be safe
http://atitool.ocfaq.com/
PostPosted: Wed Aug 11, 2004 8:22 pm
Thanks for the help guys. I used ATITool and oc'ed a bit, not much, just enough for a few fps more in games. Clock up to 425 and mem up to 220. Used 3d and 2d profiles though. 3d profiles are oc'ed while 2d are underclocked a decent amount. I was typing on AIM and all of a sudden my computer rebooted on me very randomly. After boot up into Windows, opening programs was lagging like crazy. It wasn't a cause of programs loading either on startup. Only about 1-2 programs should be loading, use MSconfig and HijackThis to keep startup fresh and clean. Any ideas why it might have rebooted like that while it was underclocked? Thanks again for help
PostPosted: Wed Aug 11, 2004 9:05 pm
no real point in underclocking it, might just cause instability - just leave it at default for normal every-day stuff and then have it oc'd for games
PostPosted: Thu Aug 12, 2004 6:50 am
Gotcha, I'll try that out. Thanks for the help :D
