It is currently Fri Mar 27, 2015 4:15 am
 Post subject: Hot Athlon XP 2000 cpu
PostPosted: Wed Aug 11, 2004 6:14 am
Please assist...I have taken quite a few steps to try and keep my cpu at the recommended operating temp with no success...I have installed a new fan & heatsink (Coolermaster) with paste....also have added another case fan. I have an Asus A7V333 mobo with 256mb.....the cpu consistently runs at 140 F and everything I've read says it should not be run over 130 F...I'm not overclocking...any input appreciated.....
 Post subject: Too much paste
PostPosted: Wed Aug 11, 2004 8:28 am
You might have put on too much thermal paste. Too much is almost but not quite as bad as no paste at all. :D
Clean off all the paste from your fan and processor make sure you don't leave any dust from the cloth and re-apply a very thin layer to the processor and an extreamly thin layer to the fan but you don't even have to do that. I do but just because.
Now if its not the paste check to make sure the fans are blowing in the correct direction.
