It is currently Fri Jan 30, 2015 9:49 pm
 Post subject: HTML Questions
PostPosted: Tue Aug 10, 2004 4:48 am
Here's the site i'm working on
http://www.musicbaltimore.com/test/
I want to know if there's a way to make a link to the popup window on the index.htm page, .
I basically just want the site to come up like it does, a fixed width and height, and no explorer buttons.
And I plan on making a low speed and a high speed version, so it would be better if i could get the window to come up manually instead of automatically.
PostPosted: Tue Aug 10, 2004 5:24 am
nevermind, i figured it out
PostPosted: Tue Aug 10, 2004 6:16 am
... but i have another question. how make sure the site isn't disabled by someones popup blocker?
PostPosted: Tue Aug 10, 2004 8:46 am
Monkey Federation (Top 10)*
Teach them, or provide a little instructional ditty about how to use their Shift key?
PostPosted: Tue Aug 10, 2004 1:39 pm
Bitchin' Fast 3D Z8000*
Let me ask you a question, why does it need to popup? That shit is very annoying - I'll open another window if I want another window opened. FYI, my popup blocker silently blocked it and I wouldn't have known anything else was there, which is fine by me since 99% of popups are total crap.
PostPosted: Tue Aug 10, 2004 1:40 pm
Just don't use stupid popups, or popunders... they're annoying. Simple.
PostPosted: Tue Aug 10, 2004 1:55 pm
100% agreed. :)
They should be outlawed!
Does the PM notification deal work for you here? I had to enable me.
PostPosted: Tue Aug 10, 2004 2:01 pm
I disabled that. I can read the little text that says "You have x new messages".
PostPosted: Tue Aug 10, 2004 2:02 pm
It is nice to know if you are having a little convo with someone. Plus, we all know that I don't actually read anything before posting, so it really helps me out.
PostPosted: Tue Aug 10, 2004 2:15 pm
Yes... that is my only expetion.... all others are blocked.
PostPosted: Tue Aug 10, 2004 2:17 pm
Do you realize that you represent about 6% of all posts on this forum? :shock:
PostPosted: Tue Aug 10, 2004 2:22 pm
Is that all? It use to be up around 14%.
PostPosted: Tue Aug 10, 2004 4:01 pm
Yes, I remember.... you must have some severe carpal tunnel... :)
PostPosted: Wed Aug 11, 2004 7:22 am
Naw, my wrists are in good shape for other reasons. ;)
