It is currently Mon Jan 26, 2015 2:47 am
 Post subject: mobo problem
PostPosted: Fri Aug 06, 2004 12:01 am
i cant find out the model of my Intel motherboard so i can get the lastest bios. also if i get the new bios would it help me oc because right now i cant do any of the things you guys are talking about.
PostPosted: Fri Aug 06, 2004 3:01 am
if u have a prefab computer, just look up the model # on the manufacturer's website to see if there are any updates. still doesnt guarantee that u will be able to overclock anything tho.
PostPosted: Fri Aug 06, 2004 9:03 pm
thats the problem i need to find the model number
PostPosted: Fri Aug 06, 2004 10:23 pm
the model # of the actual computer, not the motherboard. if it's a prefab computer by a big company (ie. dell, gateway, hp, etc) then the model # of the actual PC should be pretty easy to find. then u should be able to find out all the information on the system from the manufacturer's website.
if it's not a prefab, then u can open ur case and look for a model #, most boards ive seen have the model # and brand and such written between the PCI slots.
PostPosted: Sat Aug 07, 2004 2:14 am
CPUz
or
SiSoft Sandra
CPUz is handy for basic info, and Sandra is simply just nice for just about anything. Both should be able to tell you the board info, or at least point you in the right direction.
(in CPUz, click on the "motherboard" tab. In Sandra, click on "Mainboard Information" in the Information area. Please report back...)
PostPosted: Sat Aug 07, 2004 9:57 am
thanks both for the help it fixed my problem
