It is currently Sat Apr 18, 2015 4:36 am
 Post subject: Antec P180
PostPosted: Mon Jun 20, 2005 11:02 pm
What do I got to do to get you guys to test an Antec P180? It's easily the coolest case I've seen and is reputably quiet, not to mention painstakingly detailed. Also, anyone here know what power supplies will work with it off hand? I'd assume anything that works in a Silverstone Temjin will be fine.
PostPosted: Tue Jun 21, 2005 2:56 pm
We have one here and are probably going to test it for the next issue. It looks pretty sweet and should be quiet with its triple-panel doors and quiet fans.
PostPosted: Tue Jun 21, 2005 3:14 pm
Aight, sounds good to me. :)
PostPosted: Sat Jul 23, 2005 2:48 pm
Hey, I'm sure you guys can find a short list of what PSU's would work with this case. Anyway I can get you guys to do that for me? I need something long enough to hit the DFI UT NF3 as well as have 2 4 pins long enough to touch the two top drive bays. If all else fails I can go PCPC but that is expensive.
