It is currently Wed Jun 19, 2013 4:13 am
 Post subject: Matrix trasposition alogrithm
PostPosted: Fri Jul 30, 2004 9:28 am
Bitchin' Fast 3D Z8000*
Does anyone know the name of an algorithm that does in-place matrix transposition on a one dimensional array? None of my texts covers it. It has to be in-place, only a single array. Thanks.
example
matrix
0 1 2
3 4 5
array: [ 0, 1, 2, 3, 4, 5 ] -- using row major format
trasposed matrix
0 3
1 4
2 5
array: [ 0, 3, 1, 4, 2, 5 ]
PostPosted: Sat Jul 31, 2004 8:23 pm
I guess know one has Knuth laying around? :)
Here is a link that talks about the process a little, but like every other one, it doesn't actually explain it.
http://webdocs.caspur.it/ibm/web/essl-3 ... HDRHSGETMI
PostPosted: Mon Aug 02, 2004 3:10 pm
I haven't any of my school texts with me (they are on the other side of the country ... :( ), and I did a google search with no results.
So ... I asked the smartest math person I know. If she gives me an answer, I'll post it for you. I've also encouraged her to have a look at our folder. To be honest, though, she probably has enough interaction with geeks as it is. :lol:
PostPosted: Mon Aug 02, 2004 4:20 pm
Gadget: my friend posted a .pdf of a solution on her website. I'm going to pm you the URL. :) It is "Brenner's matrix in-place transposition algorithm" and is, apparently, a significant improvement on Knuth's algo. From ACM Algorithm 467. :)
PostPosted: Tue Aug 03, 2004 8:37 am
Never heard of Knuth. But just from reading the posts and a little research apparently he was big. lol
PostPosted: Tue Aug 03, 2004 12:18 pm
Huge. :)
I have figured out how to transpose square matrices inplace (that was actually pretty easy), and I think I have the non-squares figured out now too. That is on my home computer - I'll finish it off some time tonight.
