It is currently Tue Mar 31, 2015 4:42 am
 Post subject: file system question
PostPosted: Mon Aug 02, 2004 4:35 pm
i have a 200 gig maxtor drive formatted with NTFS, and Windows XP reads the drive fine.
However, when i go to use the same drive in windows 2000, it says the drive is not formatted.
i tried doing a chkdsk with partition magic and it says the drive is fine and recognizes the drive fine.
anyway that i can get windows 2000 to read the drive?
 Post subject: Re: file system question
PostPosted: Mon Aug 02, 2004 9:06 pm
i believe Windows XP uses a newer version of NTFS. can't network the computers?
PostPosted: Mon Aug 02, 2004 9:26 pm
yea, i could connect a hub and just copy the files, but i wanted to try and avoid that
thanks anyways :)
