It is currently Thu May 07, 2015 2:01 am
 Post subject: Processes running on WinXP
PostPosted: Sat Jul 31, 2004 9:30 pm
I am trying to identify the following processes that are running at startup on WinXP. Any help would be appreciated. I tried microsoft and google and can get any info.
utywion.exe
uxctc.exe
qorho.exe
iwvcqj.exe
Thanks
PostPosted: Sat Jul 31, 2004 9:40 pm
looks like spyware i had on my computer, it would generate a new randomly named process and add an exe file in my windows/system32 folder every time u killed the process. so that may be what it is, i would try scanning with Spybot: Seach and Destroy and Ad-Aware. good luck.
 Post subject: Re: Processes running on WinXP
PostPosted: Sat Jul 31, 2004 10:03 pm
utywion.exe
uxctc.exe
qorho.exe
iwvcqj.exe
Thanks
hmmm, yeah I'm voting spy/malware, I second the spybot/adaware suggestion, and you do have updated Antivirus right? if not I suggest AVG.
PostPosted: Sat Jul 31, 2004 11:59 pm
also try another program called hijackthis. be very careful using this program though because if you delete something that is not suppose to be deleted, your comp might not work right, well some programs or something like that. trust me, i made this mistake but i dont really care.
