It is currently Sun May 03, 2015 6:22 pm
 Post subject: It's GO time, Kids!!
PostPosted: Fri May 20, 2005 11:31 am
Folding Master (Top-ranked)
Ok, so after seeing my name start falling rapidly from number 1 producer (after Hyppy left, briefly) to 5th and falling still. I decided to come in on my own time and "fix" my stuff. As of right now (3:20 EST, I'll check again in 45min. ) The top 5 producers are over 4KPPD with me bringing up the rear.
I will be #1 producer again....not only that I will take over the top spot on the team as well. It will be mine, and mine alone. I'm telling you, I'm coming for you and folding Hell is coming with me. :wink:
Points for past 24 hours.
R&M - 5432
PcPaL71 - 5311
beelzebob - 5048
Hyppy - 4236
TWBalls - 3084
Cheers, everyone and have a great weekend!!
 Post subject: Re: It's GO time, Kids!!
PostPosted: Fri May 20, 2005 12:02 pm
PcPaL71 wrote:
TWBalls - 3084
Just as an FYI, I've got some of my PC's down currently.
PostPosted: Sat May 21, 2005 9:51 am
Location: Kicking the crap out of the people who lied to me about using Folding@Home and those who declined!!
Sure...
PostPosted: Sat May 21, 2005 12:34 pm
TWBalls wrote:
PcPaL71 wrote:
TWBalls - 3084
I thought as much, you were knocking on my door too much not to have some down....
....on another note. I just checked Hyppy last 24hr output.....7000+ Looks like I will have to follow my own advice as well.
PostPosted: Sat May 21, 2005 2:43 pm
DrSatan wrote:
Sure...
:P
Seriously though, I had 3x P4 2.4B, 1 P4 3.0E and a P4 2.8 OC'd to 3.08 all down.
Of the 2.4B's, I have a total of 4. I set up 1 for our HR dept. After I got that they way I wanted it, I made an image of the HDD and put that on my 'folding shelf'. The other 3, I had down because I was imaging their drives and then setting them up for the individual user. Rest assured, after I finished them I put them back up to fold. :)
I needed a PATA drive for another system, so I imaged the OC'd 2.8 and took the disk out of that. Then I slapped a little 40GB SATA drive in it and recovered using the image. So that one is also now back up and running.
The 3.0 we just got in 2 days ago. We got 3 of those, but didn't have time to set them all up to fold right away. I had the 1 leftover that was sitting there doing nothing. I got stuck at work after hours waiting for my ride, so I went ahead and hooked that up and installed VNC on it so that I can tap into it and set that up. I'm currently setting that one up right now from home. :)
PostPosted: Sun May 22, 2005 11:00 am
TWBalls wrote:
DrSatan wrote:
Sure...
:P
Sure...
PostPosted: Sun May 22, 2005 11:07 pm
Nobody can defeat my rank of 281!
NEVAR!
PostPosted: Mon May 23, 2005 6:33 am
DrSatan wrote:
Sure...
:P
I've got them all up and folding now, as well as an AthlonXP 2200+. I'll likely be putting that AthlonXP/motherboard up on the FAH FS/FT table. I'm gonna do some burn in testing first. Don't wanna put up a bunch of crap parts that don't work. ;)
PostPosted: Mon May 23, 2005 12:58 pm
Sure...
PostPosted: Mon May 23, 2005 1:29 pm
DrSatan wrote:
Sure...
Damn you.
I fart in your general direction. :Fart:
PostPosted: Mon May 23, 2005 1:31 pm
Sure...
PostPosted: Mon May 23, 2005 6:54 pm
275!
I am the William Wallace of folding!
YEEEAHAGHGGH
