It is currently Tue Apr 21, 2015 1:01 am
 Post subject: infamous.exe???
PostPosted: Sat Jul 31, 2004 8:11 pm
Hi
I was online on a website, cant recall which when I was online using america online 9.0 SE on windows XP when a dos program with the heading c:\windows\infamous.exe opened
Then an error appeared it said:
16 bit MS-DOS Subsystem
c:\windoes\infamous.exe
The NTVDM CPU has encountered an illegal instruction.
CS:054b IP:01c9 OP:63 73 73 22 20 Choose 'Close' to terminate the application.
has the options Close and Ignore
I dont know where the error log is so I cant get detailed information
hope you can help,
Riddler123
PostPosted: Sat Jul 31, 2004 10:49 pm
It's not good, I can say that much!
TROJ_SMALL.IQ
http://www.trendmicro.com/vinfo/virusen ... IQ&VSect=T
 Post subject: Re: infamous.exe???
PostPosted: Sat Jul 31, 2004 10:56 pm
Riddler123 wrote:
Hi
hope you can help,
Riddler123
O\/\/3n3d... sounds like ya'll might want to get ready for the reinstall, because I could never trust a computer compromised by somehting like that again. I'd fully reformat that shite and start over (with good firewall and Antivirus).
PostPosted: Sun Aug 01, 2004 5:08 am
To find out more about the .exe ....Start>control panel>Administrative tools>event viewer>application log. Look in there for any info on your .exe problem.
You can get a free antivirus here:
http://free.grisoft.com/freeweb.php/doc/2/ I use it and it works great!!
You can get a free firewall here:
http://www.zonelabs.com/store/content/c ... wnload.jsp
I use this also and it works great also!!
Download Spybot, Ad- Aware and CW Shredder from here: All free too;)
http://www.majorgeeks.com/ These programs get rid of Spyware on your system.
