It is currently Mon Mar 30, 2015 9:54 pm
 Post subject: Power supply question.
PostPosted: Tue Jul 27, 2004 9:27 am
Hey guys, I've got a question. I'm wanting to replace the stock power supply in my Dell computer (which is only a 250 watt PS) with an Antec 480 watt PS and I'm wondering does anyone know whether or not this is possible? The reason is that I know that Dell uses a lot of proprietary parts (motherboards) and I'm hoping that they didn't change some wiring around so that you would have to get a PS from them. Thanks for the help in advance.
My specs.......
Dell Dimension 8250
P4@3.06 Ghz
1024 Mb 1066 Rdram
Radeon 9700 pro (slightly overclocked)
WD 200 gig Hard drive @ 7200 RPM
Sound Blaster Audigy 2
XP home
PostPosted: Tue Jul 27, 2004 9:40 am
hmmm.....to me its possible but it depends on the case, hopefully the antec power supply will fit in. i suggest you try it and see. im optimistic about it though.
PostPosted: Tue Jul 27, 2004 9:59 am
Shouldnt be a problem but as stated above, Dell cases tend to be on the small side, so you might not be able to fit the PSU in the case.
PostPosted: Tue Jul 27, 2004 10:21 am
If anything, it will be a physical fit problem, not wiring. You may have to do, say, a little "modding" and tinkering around, but otherwise, you shouldn't have to do any complicated re-wiring or anything.
 Post subject: Watch out
PostPosted: Tue Jul 27, 2004 10:42 am
Team Member Top 100
Team Member Top 100
I recall reading (I'm pretty sure it was in MaxPC, but I cannot recall which month) that Dell does not use the standard ATX wiring specification even though their connectors use the same pin count.
Here's a link that gives the wiring diagram for standard ATX vs. Dell's connector.
Do some homework before you shell out for a new power supply.
Hope that helps.
PostPosted: Tue Jul 27, 2004 11:14 am
Ahhhh, now THAT'S what I'm looking for! I don't have a problem doing some homework on it, but I needed to be pointed in the right direction. Thanks again
PostPosted: Tue Jul 27, 2004 1:08 pm
Did you not have a choice on the PSU for your PC system? I would hope that they offer juicier PSU than 250W. That might not even be 250W due to the decline of power output due to heat.
PostPosted: Tue Jul 27, 2004 2:19 pm
you can check out http://www.pcpowerandcooling.com to find an alternate PSU to the Antec that should definitely fit in your case.
PostPosted: Wed Jul 28, 2004 7:56 am
7yrs+11,000 Posts
7yrs+11,000 Posts
the other day in my dell dimesion my floppy went bad. I changed the floppy and everything but alot of the parts were looked custom by delll. I didnt pay close attention to the psu tho
 Post subject: proprietery psu connector
PostPosted: Wed Jul 28, 2004 8:14 am
Many Dell's use a proprietary PSU & motherboard connector. What I recommend is opening up the case & taking a look at the connection to the motherboard. Usually it's a standard ATX connector, with an additional pigtail connection to another connector on the mobo. Many aftermarket PSU's provide this additional connector though, you'll just need to do a little homework :)
HTH,
Bill
PostPosted: Wed Jul 28, 2004 10:24 am
That's just one of the many reasons why I'll only build my own computer, not buy them from an OEM (well, except for Alienware). I like to know every component that goes into my computer.
PostPosted: Sat Jul 31, 2004 10:05 am
My advice is not to put the power supply in. I've heard horror stories about dell and changing the PS
PostPosted: Sat Jul 31, 2004 10:20 am
Dell's do / did use a proprietary PSU, You can't just look and see if it's got special connectors cause it looks like a regular ATX, it's just wired differently 12V where 5V would be on a normal PSU, etc. You can find some directions for modding a dell powersupply to work on a standard ATX MB here, it should be fairly straightforward from those on how to modify a standard ATX PSU to work on a Dell motherboard.
