It is currently Sat Mar 28, 2015 8:23 am
 Post subject: ripping as mp3's in windows xp media player 9
PostPosted: Thu Jul 29, 2004 8:44 pm
icurrently have windows xp and windows media player 9 i did what this iste said about it but it still wont let me rip as mp3's
PostPosted: Thu Jul 29, 2004 8:50 pm
Astro lube 2 the MAX!
I think at a point they did rip as mp3s, but you have to pay royalities to use the MP3 codec. So windows created their own, .wma file extension. And seems that is the only option to rip to.
If you wanna try, use LAME.
But I currently use iTunes as my music player, and it has a free MP3 encoder built in.
PostPosted: Thu Jul 29, 2004 9:00 pm
i use itunes also i cant find the ripper so i rip with musicmatch
back to the topic i messed with the registry and wmp allowed mp3's as an option but then when i started the ripping it said their was no compatible mp3 encoder im not sure if i did something wrong or the instructions were wrong
PostPosted: Thu Jul 29, 2004 9:38 pm
http://www.maximumpc.com/forum/viewtopic.php?t=1360
PostPosted: Fri Jul 30, 2004 10:04 am
sorry about not putting the systen specs i have a custom made computer made by some old guy that hates me. He put the cheapest parts he could find to put into my computer so im not sure about the specs ill look it up then try again later
PostPosted: Fri Jul 30, 2004 11:15 am
You can use Exact Audio Copy and LAME in an effective combo that can extract some severely damaged CDs.
Or you can use CDex, which is easier to setup and use, IMO.
Both setups are completely free.
PostPosted: Fri Jul 30, 2004 12:56 pm
I used to use Cdex but have recently switched to EAC and LAME and I couldn't be happier.
PostPosted: Fri Jul 30, 2004 1:28 pm
Nonetheless, you could post simple things like the OS you are using ... this really helps us help you. :)
Also, all of your devices are listed in your Control Panel ... it is worth finding where ... you'll learn while digging.
PostPosted: Fri Jul 30, 2004 3:19 pm
I tried using EAC and LAME recently (at the suggestions of the newest issue of Maximum PC no less), and it caused my PC to reboot everytime I ran the .exe file. After than Winamp would no longer run. I had to uninstall and reinstall it.
Strange...my PC works just fine otherwise.
Just for clarity, the pc in question is:
Intel P4 2.8 Ghz
1GB RAM
Asus p4-533X mobo (i might have the numbers a little off)
Win XP Pro
I think I'll try CD-ex instead. I tried iTunes, but only saw AAC encoding (I didn't look that hard).
PostPosted: Fri Jul 30, 2004 3:58 pm
which version of EAC are you using?
PostPosted: Fri Jul 30, 2004 7:34 pm
Don't remember...I've since deleted the files, but judging by the dates, I'd guess it was Exact Audio Copy V0.95 prebeta 5
PostPosted: Sat Jul 31, 2004 5:45 pm
I use that version, and I've never had a problem with it. In fact, it perfectly ripped a CD that had a speck of the reflective material gone. It is a tiny speck but a speck nonetheless.
PostPosted: Sat Jul 31, 2004 7:12 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
go to downloads.com and download a program called free cd ripper it works and i suggest u use winamp instead of windows media
PostPosted: Sat Jul 31, 2004 8:12 pm
Can't go wrong with EAC and LAME....
PostPosted: Mon Aug 02, 2004 2:04 pm
There is actually a very simple registry hack to enable ripping mp3's with WMP9, although like the people above stated, its probably wiser to use a better quality one.
Here is the text in a *.REG file:
Quote:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MediaPlayer\Settings\MP3Encoding]
"LowRate"=dword:00017700
"MediumRate"=dword:0001f400
"HighRate"=dword:0002ee00
Copy that text into "MP3RegHack.reg" using notepad and run it. (dont worry, i tested this on my own machine and its safe and it works)
