It is currently Wed Apr 01, 2015 2:07 pm
 Post subject: Pull protected files off HDD
PostPosted: Thu Jul 29, 2004 9:30 am
I pulled everything out of my old computer because of problems. I am trying to get some of the files off my HDD with another computer running the HDD as slave. I can't get into the folder, it says "access denied" each time because it was a password protected user on that machine. Anyone know of a fix or way around this so I can salvage my docs?
PostPosted: Thu Jul 29, 2004 10:30 am
put in the password?
PostPosted: Thu Jul 29, 2004 10:52 am
He can't .. he is running the HD on a new machine.
Umm ... were the files encrypted or just password protected?
PostPosted: Thu Jul 29, 2004 10:57 am
Is the HDD formatted as FAT32 or NTFS?
 Post subject: Re: Pull protected files off HDD
PostPosted: Thu Jul 29, 2004 11:08 am
You need to take ownership of the drive. Disable Simple File Sharing.
To display the Security tab
Open Folder Options in Control Panel.
Click Start, and then click Control Panel.
Click Appearance and Themes, and then click Folder Options.
On the View tab, under Advanced settings, clear Use simple file sharing [Recommended].
Now you will have a Security tab on the drive. Right click the drive and select Properties. Go to the Security tab and press the Advanced button.
Switch to the Owner tab and make yourself the owner. Make sure you check the box in the lower left to Replace the owner on subcontainers and objects. After that is finished you will be able to access everything on the drive.
 Post subject: Not exactly
PostPosted: Fri Jul 30, 2004 11:29 am
I know what you are talking about RKilroy, and I know it is the way to go but...I don't have the "Appearance and Themes" folder. But I go into the folder options and then view tab but there is not an advanced option. I also tried going into the properties of the drive and couldn't find anything. I am using XP home, let me know if you know where I can go from here... thanks
 Post subject: Re: Not exactly
PostPosted: Fri Jul 30, 2004 12:13 pm
Get a friend who has XP Pro. or Win2000.
PostPosted: Fri Jul 30, 2004 3:04 pm
You've probably switched to Classic View. Open up My Computer go to Tools\Folder Options. Switch to the View Tab. It is the very last box.
