It is currently Sun Mar 01, 2015 4:16 pm
 Post subject: Upgrading an old Dell
PostPosted: Wed Jul 28, 2004 5:19 am
I have a friend that needs his computer upgraded. Its an old Dell (i forgot to get the model) that has a 1 Ghz PIII, 128 mb of 168 pin SDRAM, a 20 gig Hd and onboard video.
My question is, if I put another hard drive on with his current hard drive and try to re-install the Windows ME that came ith the computer on a reinstall disk :| (after a format of course), will the install work with different hard drive?
Also, can the old Dell motherboards have 2 hard drives at once on a single IDE contoller?
thanks for any feedback. I hope i dont come off as any n00b, but ive been reading maximum PC since i was 10 (1999) and ive been building machines for myself, friends and family since. Ive never had to upgrade an old mass produced computer :?
-Cleatis
PostPosted: Wed Jul 28, 2004 6:04 am
i dont see why it wouldnt work, should install just fine.
and the question about 2 HDs on 1 IDE channel, that should also work, provided the PSU is strong enuff to push it.
PostPosted: Wed Jul 28, 2004 6:08 am
Thanks for the feedback :)
-Cleatis
PostPosted: Wed Jul 28, 2004 7:31 am
7yrs+11,000 Posts
7yrs+11,000 Posts
is it a dell dimention, it sounds like one, i only know cuz i have one.
PostPosted: Thu Jul 29, 2004 4:33 pm
Yes you can format the new drive and install windows ME (YUK) on it, if you have it jumpered as master and the old drive set as slave, format the old drive before you start.
PostPosted: Thu Jul 29, 2004 4:56 pm
ok.. and another thing... i did more research on this particular computer and it needs PC100 ram... that stuff is expencive. is it possible to put PC133 in?
PostPosted: Thu Jul 29, 2004 5:10 pm
Those old systems aren't worth updating ram, sometimes the genaric ram you buy may not work. That happened at work with a Gateway we had for a cad program. If you decide to buy ram be sure you can get a refund if it don't work. PC 133 will default to PC100 if you already have a stick in the system. If you have computer fairs where you live go to one. I bought a stick of pc 100 for 30 bucks...it was 64 megs.
I duel boot and have win98se running with 512 megs of ram, that is the limit for that operating system. I would like to add another 512 so my win 2000 pro works better but can't because of win98se limits.
