It is currently Wed Jan 28, 2015 10:48 pm
 Post subject: videocard software?
PostPosted: Thu Jul 29, 2004 2:39 pm
hey-I need some software that will tell me how hot my GPU is running on my 9800 Pro. I want to overclock it w/ Powerstrip, but I dont want to fry my 200$ card. Also, how hot can a 9800 pro get?
PostPosted: Thu Jul 29, 2004 2:49 pm
King of All Voodoo2 Cards
I don't think anyone overclocks their cards while monitoring temps, but I could be wrong.
Usually, you bump up the speed in increments and run 3DMark until there's noticable artifacts on the screen then back off by about 15% for a little headroom.
PostPosted: Thu Jul 29, 2004 3:07 pm
alright-ill do that then-i guess ill also run intense games too to see any screen artifacts.thanks
PostPosted: Thu Jul 29, 2004 3:20 pm
u could always just put ur hand on the heatsink if u cant find any temperature monitoring software ... old school, but it works.
PostPosted: Thu Jul 29, 2004 3:46 pm
Hi
Unless you have an 9800 XT, I don't think you'll find a temp monitor. Here's a couple quick ideas.
1) Don't put your hand on the heatsink, put it on the back of the CPU core instead. It will be hot...you'll probably be suprised at how hot it will be, Mine was pushing 60 degrees before I watercooled it. That's a fairly normal temp for high end video cards.
2) If you want to continually monitor your temps, you could pick up a fan controller with a thermal sensor. That way you can constantly monitor all the temps in your case.
that's all I can think of at the moment..hope it helps
PostPosted: Thu Jul 29, 2004 3:52 pm
depending on the card, that could cross a contact, which is why i didnt suggest it ... but that would be better, just be careful what you touch.
PostPosted: Thu Jul 29, 2004 4:24 pm
Good point.
With my 9800 pro there is a "bald spot" for a lack of a better term, on the back of the card where the core is. I also have the heat sensor placed there.
PostPosted: Sun Aug 08, 2004 5:30 pm
Screw powerstrip if all you want to do is overclock your ATI card. I've been using ATItool for awhile now and it overclocks and monitors your temps. I don't know how reliable it is for temps but it does change depending on usage. Get it here!
http://atitool.ocfaq.com/
PostPosted: Mon Aug 09, 2004 6:39 pm
is powerstrip good overclock tool for nforce cards
PostPosted: Mon Aug 09, 2004 8:14 pm
nVidia Video cards or nForce Motherboards? If it's nVidia Video cards, then I have a little trick for you!
  • Do all the normal percautionary stuff you should do when you edit the registry. Because that's what you are about to do.
  • Go to Start->Run->type rededit
  • Open HKEY local machine->Software->NVIDIA Corporation->Global->NVTweak
  • In a bare (white) area of the right pane, right click
  • Chose "New" then "DWORD" value
  • Name this new Dword "Coolbits"
  • Double click your new Coolbits to get the properties.
  • In Value Data field, put in "3" and insure "Hexidecimal" is checked.
  • Close out the registry editor.
Now when you right click on your desktop and go to your properties, You go to the settings tab, click the advanced button, and go to your card's settings tab (usually the back one on the right) you should have a new "Clock Frequencies" setting to play with.
And you made this all by yourself, so go rejoice at your new found wisedom and try to see how to get the smoke out of your card :)
PostPosted: Mon Aug 09, 2004 9:58 pm
i heard of this tip from overclockers.com but they didnt go into the steps for it so thanks a lot.
PostPosted: Tue Aug 10, 2004 4:21 pm
if i'm not mistaken MAXPC put an article in a past issue advertising a laser temp reader. it looks like a gun but its measures heat by shooting a laser to the designated area. i found this on a msn search http://www.linseis.com/lpt600.htm
PostPosted: Tue Aug 10, 2004 11:13 pm
first off, IMO, I think you'd be a bit better off using Omega drivers, and radlinker for OCing your vid card. In my personal experience, powerstrip wasn't too friendly.
If you wanna monitor temps while OCing the vid, I'd say the best way would be to add a thermal probe to the back of your vid card's gpu, and either mount a small thermal readout display to the front of your rig, or figure out a way to hook up the temp probe to your mobo, so you can using something like Mother board monitor 5 to display the temp.
What video card do you use?
From what I've heard, higher up ATi cards like the 9800 pro's have gpu temp support, but I have no idea really.
PostPosted: Thu Aug 12, 2004 3:20 am
Ya! One of these:
They run around $100 though, with this Raytek Raynger ST running a heafty $310. Not for the feint of heart. But hey, you can tune carberators and check tire temperatures...nice for the average racer/PC geek :D
A warm and hearty "welcome back" dude!
Users browsing this forum: mrmarrero and 11 guests
