It is currently Wed May 22, 2013 1:30 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Wed Jul 28, 2004 6:06 pm
I'd rather be modding!
Gadget wrote:
MantaBase wrote:
gamerfreak wrote:
thanks alot for you ansewers but i just wanted to do it as a hobby. Lol they really helped though. I bought at cheap luttle book by Mike Mcgrath called " C++ programing in easy steps" its probebly junk though. In the post wayy up html goodies was mensioned. Yeah it is a web desighning standards books and its the best one out there. Most of the material in the book can be found on www.htmlgoodies.com Its a really great book if you are starting out html and even if you know it its a great refence.
If its just a hobby I would start with Python and then Java.
"Python Programming: For the absolute beginner" Premier press by Micheal Dawson.
By the time you finish the book you have programmed "Asteroids" and have the skill to do much more. Its also a great kick start into OOP.
Manta (Manta is a noob as well at programming - be advised)
Nice.... I'll try and find that one at borders today. :)
You are likely beyond it - but I am finding it a good transition from linear to OOP. You could finish it in a few hours I bet.
Its a bit Python braggy BTW *shrug*
Manta
PostPosted: Fri Aug 06, 2004 9:57 am
starting with C/C++ or Java is always good.
