It is currently Wed Apr 01, 2015 6:18 pm
 Post subject: Voltages?
PostPosted: Tue Jul 27, 2004 9:16 am
I've overclocked my P4 3.0 northwood to 3.4 without any problems running on a Corsair 200ex WC kit. I've heard that beyond 400mhz, I need to adjust my voltages. How would I do that? and what does it do?
PostPosted: Tue Jul 27, 2004 11:18 am
Forum's Goatkeeper
Forum's Goatkeeper
You go into the BIOS, and adjust the CPU vcore voltage.
And to be quite blunt, if you don't understand what that will do, you probably shouldn't be messing with it in the first place.
 Post subject: Re: Voltages?
PostPosted: Tue Jul 27, 2004 1:03 pm
Contributing Writer
Contributing Writer
I've found the quality of the RAM, as well as voltages for the RAM, to be infinitely more important than the vcore on a P4C setup. This is not to say that's it's worthless, but there's really no reason to play with voltages unless you're experiencing stability problems.
I'll second Raven's bluntness in that you need to be educated on what you're getting into (not just on voltages) before poking around in the BIOS. Here's a couple links to get you started:
Detailed BIOS Guide
Overclockers.com
PostPosted: Tue Jul 27, 2004 4:18 pm
im with Raven...dont mess with it...you also should probably put it back to stock speeds...
also like Raven said, it doesnt seem like you know what you are doing
PostPosted: Wed Jul 28, 2004 4:47 am
As previously stated, do not increase VCore unless you experience stability problems.
I suggest you do a little more research for your particular rig via http://www.google.com.
