It is currently Sun May 03, 2015 1:04 am
 Post subject: Best heatsink/fan to OC AMD Barton 2500+ mobile
PostPosted: Tue Jul 27, 2004 10:12 am
Like the topic says, I want to overclock the 2500+ Mobile and i was wondering what the best heatsink and fan to use are.
BTW, I have:
Asus A7N8X-E Deluxe
1 Gig XMS series PC3200
9800 Pro
etc.
Thanks a lot! :D
*I would like to spend between $20-30*
Last edited by ActionJackson147 on Tue Jul 27, 2004 10:15 am, edited 1 time in total.
zalman cu-7000
PostPosted: Wed Jul 28, 2004 1:50 pm
Celeron
Celeron
check out this link:
http://overclockers.com/articles373/socketA.asp
in the $20-$30 range, i like the vantec aeroflow, with the tmd fan. it goes for ~$25.
http://www.newegg.com/app/ViewProductDe ... 007&depa=0
however, i dont think the ranking is correct for the zalman, as it ranks below the vantec. it should be at a higher rank. consider that if you want to spend a little more.
