It is currently Fri Feb 27, 2015 3:50 am
 Post subject: backdoor-cfb- virus
PostPosted: Sat Jul 24, 2004 8:02 am
Hi users,
I am having a problem with the Backdoor-CFB worm. I get messages on my Windows XP system that the virus has been detected by McAfee, but it says it cannot delete or quarantine it.
Any help or suggestions would be helpful and appreciated.
PostPosted: Sat Jul 24, 2004 8:47 am
http://www.sarc.com
PostPosted: Sat Jul 24, 2004 8:50 am
also try running your Anti-Virus in Safe Mode.
You could go manually delete the file(s) while you're in safe mode, but make sure they are not critical files for your OS or programs.
PostPosted: Sat Jul 24, 2004 11:38 am
try downloading and installing another anti-virus program like AVG which is really good for an anti-virus program. then once you install AVG, update the virus database and run a full complete virus scan on your comp. see if AVG gets rid of the virus.
