It is currently Fri Apr 17, 2015 8:16 pm
Post new topic Reply to topic  [ 19 posts ]
 Post subject: NEC ND-3500A or ND-3520A
PostPosted: Mon Mar 07, 2005 4:12 pm
What's the difference? I see people recommending the 3520A over the 3500A and the 3520A seems to be a bit cheaper... So which one?
Oh, and does anyone know where Dual Layer Media can be purchased? (Along with DVD+-R[W] CD-R[W] if possible)
PostPosted: Mon Mar 07, 2005 4:16 pm
Celeron
Celeron
3520A is the newer model. Get it.
There's some DL discs at newegg. I'm sure someone will come up with a better site for specfically media.
Edited for clarification.
PostPosted: Mon Mar 07, 2005 4:30 pm
3520A
PostPosted: Mon Mar 07, 2005 5:07 pm
yea, its just an incremental update to the 3500a. its like the x850xt, nothing new, just a slight update.
PostPosted: Tue Mar 08, 2005 11:05 am
hey kyl3
get the NEC 3520a, its the update of the NEC 3500a and i heard good performance of it. get the 3520a.
PostPosted: Tue Mar 08, 2005 9:17 pm
I just read recently that the 3520a is the OEM version of the 3500a. I just got the 3520 from newegg for 57 bucks. Damn thing is so quiet I have to look to see if its running. I cant tell you about burn speeds cuz I havent ordered any dvd media yet.
PostPosted: Tue Mar 08, 2005 9:45 pm
The above post is completely wrong.
The 3520A is a slight revision of the 3500 (enough so that they use different chipsets and cannot use each others firmware). The only difference is its ability to burn at given speeds.
As for noise you can definetly hear them in use.
PostPosted: Tue Mar 08, 2005 10:04 pm
Well I guess PC mag gave me some wrong info as far as the 3520A being different due to it being OEM. Well after my Lite On drive this one is pretty damn quiet. I didnt say it was "silent"
Hey I found this that makes you totally correct URmumsacow
http://www.cdrinfo.com/forum/printable.asp?m=93724
PostPosted: Wed Mar 09, 2005 7:59 am
Contributing Writer
Contributing Writer
Try finding a retail 3500a - it's an oxymoron. :wink:
PostPosted: Wed Mar 09, 2005 11:28 am
Oh don't you go injecting humor into this, you'll only make more peoples brains hurt.
There IS a retail version of the 3500. And there is also a retail version of the 3520. The thing is most of NEC's money comes from the OEM sales so the can be hard to track down.
Of course, in time you to will come to never doubt my optical media knowledge.
*kung-fu pose*
PostPosted: Wed Mar 09, 2005 12:43 pm
after reading some of this site, my head really hurts :cry:
i just purchased a 3520 oem from newegg, never had a cd or dvd burner before, so all this firmware stuff way over my head, i'm just trying to get some software to burn a cd with....
does all of this mean when i put the nec in my new computer i will not be able to burn dvd's????
what is firmware and what/how do i put this stuff into my burner????
man, i am really confused now :D
PostPosted: Wed Mar 09, 2005 1:04 pm
Relax, your burner will work no matter how many times you moveit from computer to computer.
Firmware really isn't something you need to worry too much about. Firmware is what drives the burner itself so to speak, it allows your burner to know what to do with the instructions it recieves from your computer.
PostPosted: Wed Mar 09, 2005 1:48 pm
*kung-fu pose*
lol ! I like your brand of humility!!
PostPosted: Wed Mar 09, 2005 2:17 pm
hey urmumsacow.....
THANKS!!!! thought I had wasted my money on the oem nec :D
take it easy
PostPosted: Wed Mar 09, 2005 3:26 pm
If you knew anything about kung-fu or my obsession with optical drives, you'd understand the jest for what it was :wink:
PostPosted: Wed Mar 09, 2005 3:46 pm
I was "jesting" also. Ive seen you here for quite a while and respect your experience. :)
PostPosted: Wed Mar 09, 2005 3:49 pm
You are too kind. Kind sir!
PostPosted: Wed Mar 09, 2005 3:59 pm
Must be that native american shaman I hang with is rubbing off.
**hands urmumsacow a hawk feather as a gift from the spirits** lol
PostPosted: Wed Mar 09, 2005 5:35 pm
urmumsacow wrote:
3520A
agreed! I just got one, its nice!
