It is currently Wed Jun 19, 2013 9:40 pm
 Post subject: amd 64 mobo, cpu, ram
PostPosted: Fri Mar 04, 2005 5:02 pm
best recomendations for something around 600 bucks
requests...
smth around athlon 64 3400 (1MB cache)
mobo with builtin lan + audio (nothing really fancy required)
1GB RAM
PostPosted: Fri Mar 04, 2005 7:41 pm
if you are not gonna overclock your ram you can go crucial. check out www.crucial.com they make awesome ram. they have their regular line and their crucial ballistix memory which are overclockers. i have experience with crucial's regular line of memory and they work great.
they dont cost that much and i think crucial provides lifetime warranty i think. might wanna check that out.
here is what i recommend:
mobo and cpu:
http://secure.newegg.com/app/ShoppingCa ... =AddToCart
memory: crucial
http://www.crucial.com/Store/checkout/CartDetail.asp
im assuming you want only the mobo, cpu, and ram since this is what your topic is all about. probably other people can make a better recommendation.
PostPosted: Fri Mar 04, 2005 8:21 pm
heh... the shopping carts are empty... could you please link me to the pages with details on the items.
PostPosted: Fri Mar 04, 2005 8:27 pm
for ram take 2 of these and call me in the morning
you want a $600 full system? or $600 for the mobo ram cpu combo?
 Post subject: Re: amd 64 mobo, cpu, ram
PostPosted: Fri Mar 04, 2005 9:01 pm
Celeron
Celeron
ramm wrote:
requests...
1GB RAM
You're kidding on the S754 proc + mobo? There's a negligible performance difference between the 3400+ and 3500+ procs, so you might as well go with the highly supported socket (939) anyway. Or perhaps you're just catching up? Or am I acting like an ass and is forgetting something? :P
Btw, the 3400+ Clawhammers are rare.
PostPosted: Fri Mar 04, 2005 9:11 pm
im tired and doing this for a friend... to answer most the questions. This is only for the mobo, cpu, and ram. I'm not exactly sure what the prices or specs on anything are, thats why i said "around."
PostPosted: Fri Mar 04, 2005 9:53 pm
i went for the 3400 cause it was dam cheap and i dont plan to upgrade video on this box.
as for cpu ram and mobo, for $600, that's plenty.
Generally, what's suggested for great performance is a 3500+, sli or ultra mobo, and a gig of ddr3200.
so the ram i suggested (116), a 3500+ (270 - i know, not a winnie, but $60 more for something which isn't going to be oced? bah, it's not that much of an oven)
and for mobo, there's the dfi nforce4 ultra and asus nforce4 sli
you can get lower cost mobos, without missing much, and drop the proc down to a lower speed without sacrificing much power.
