It is currently Fri May 24, 2013 7:12 am
 Post subject: is this a good mobo for celeron...
PostPosted: Fri Mar 04, 2005 12:17 am
building a pc for a friend, all he wants is internet connectivity and the abilty to play ultima online, and play around with bryce and poser.
heres what i got so far:
ABIT "IS7-E2" i865PE Chipset Motherboard for Intel Socket 478 CPU ( or this one, ABIT "BE7II" i845PE Chipset Motherboard for Intel Socket 478 CPU)
Intel Celeron 2.0 GHz 400MHz FSB, 128K Cache
Corsair Value Select 184 Pin 512MB DDR PC-2700
POWERCOLOR ATI RADEON 9600PRO Video Card, 256MB DDR, 128-bit, DVI/TV-Out, 8X AGP, Model "R96-D3G"
Lite-On 52X32X52 Internal EIDE CD-RW Drive Black, Model SOHR-5238S Black
RAIDMAX Black 10-bay Case with 420W Power Supply, Model "ATX-822WBP"
so, the question is, which mobo is better?
PostPosted: Fri Mar 04, 2005 12:35 am
I'm not sure about the motherboard, but I'm sure of one thing:
Get rid of that graphics card.
Powercolor is the worst manufacturuer of graphics cards. Try trusted brands with great customer support such as eVGA, BFG, ASUS, and MSI.
PostPosted: Fri Mar 04, 2005 5:02 am
That system seems fine if he all he will be doing is web surfing.
Dont worry about the graphics card, its fine.
You prolly could save a bit more money and getting a lower tier one if hes not gonna be playing games at all.
Nice of you that you are building one for a friend.
PostPosted: Fri Mar 04, 2005 7:02 am
Go with the i865 chipset, a little more up to date than the 845 and slightly more flexible.
That video card should be okay, but I haven't heard much of anything about Powercolor. Maybe do a little more research to make sure they are reputable and not some fly-by-night.
PostPosted: Fri Mar 04, 2005 7:26 am
ATI = the devil (not really, but I am an Nvida guy)
Powercooler = satan's lacky
get an Nvida FX 5XXX is my reccomendation
You will be quite please with that Celeron they perform much better than the original ones, but if you can get a 2.2 or 2.4 I would recommend it.
PostPosted: Fri Mar 04, 2005 9:24 am
ya get an nvidia video card instead :evil: like this one or [url=http://www.newegg.com/app/ViewProductDesc.asp?description=14-122-216&depa=1]this one[url]
[/url]
PostPosted: Fri Mar 04, 2005 6:38 pm
I wasn't criticizing the chip, I was criticizing the manufaturer.
PostPosted: Fri Mar 04, 2005 7:28 pm
Get a Celeron D with LGA 775 socket, so you can use the 925XE chipset.
