It is currently Wed Apr 01, 2015 9:25 am
 Post subject: No Insert Key on mac keyboard?
PostPosted: Mon Jul 05, 2004 8:27 pm
On an e-mac at work it seems like the insert key was pressed. In MS word it replaces stuff rather than adding it in when you try to edit things. But on they keyboard there is no insert key.
The computer is using Mac OS X panther and Office X
How do I turn off insert without an insert key
PostPosted: Mon Jul 05, 2004 8:52 pm
iron colbinator
iron colbinator
Press on the "OVR" at the bottom, toward the right. If it's selected it'll be a green dot, if it's not selected it'll be hollow. That should toggle back and forth.
I don't see any other way to do it, there aren't any keyboard commands configured on my system that will do it. I'm using Office X and just tried that.
I can post a screenshot if it will help.
 Post subject: Re: No Insert Key on mac keyboard?
PostPosted: Tue Jul 06, 2004 5:41 am
Forum's 3dfx Zealot
Forum's 3dfx Zealot
Just get a good pc usb keyboard. It will work on the mac and surprisingly the mac can understand the insert key command just fine in office x or atleast it does on my machine.
PostPosted: Wed Jul 07, 2004 10:57 am
It does not seem to have an ovr key either.
It is this keyboard I think.
http://www.macsecrets.com/2003/img/Mous ... d_emac.jpg
PostPosted: Wed Jul 07, 2004 11:39 am
iron colbinator
iron colbinator
It's not a button or a key on the keyboard, it's in a document. Open a word document, and at the bottom there are several options. OVR is one of them. Click on it, it toggles. I'm not in front of my Mac so I can't take a screenshot.
In the bottom right of this picture you can see where they start:
http://www.macdevcenter.com/mac/2002/04 ... oc_mac.jpg
Too big for me to put in my message... but it's the very bottom left next to the TRK button that you are looking for.
PostPosted: Sat Jul 10, 2004 9:53 pm
Thanks. I'll try it on monday
PostPosted: Mon Jul 12, 2004 5:22 am
do macs have an equivalent of a print screen button or do they require third party software like kde? i was trying to explain to someone where the print screen button would be but it turns out there is none on mac keyboards!
PostPosted: Fri Jul 23, 2004 7:36 am
I'd rather be modding!
Yes - but I can't remember it. Its like apple+4+shift or something like that
Ah yes - here it is:
http://www.xvsxp.com/power_user/
X has more options than XP :)
Manta
 Post subject: Re: "Insert" key on MAC keyboard?
PostPosted: Mon Oct 14, 2013 12:25 am
I'm new to this forum but just want to say a HUGE THANK YOU to Mr Colby - I got stuck really badly and did a Google search - most people asked this question because they wanted to insert something, ie. Command + V (which is paste somethign that's been copied). In my case, I had hit something and as I'm typing, the letters on the right that appear on my page were being "eaten" by my new typing. With a PC keyboard, I'd just press the "Insert" button. I tried all the buttons on the MaC keyboard - and found a post where someone said to use the "Help" button on the keyboard - well,my MAC keyboard does not have a "Help" button, very helpfully!
Some 13 years later, your post (and the person who posted the original query) has more than done it's job to help others. Thank God for that. :-) :D
PostPosted: Tue Oct 15, 2013 11:22 am
That's Mrs. Colby.
PostPosted: Tue Oct 15, 2013 11:33 pm
Sorry :? for the mix-up, Mrs Colby. Thank you.
PostPosted: Wed Oct 16, 2013 8:23 pm
She hasn't visited in over 2 years, so I think that you're fine. ;)
