It is currently Mon Mar 02, 2015 7:29 am
 Post subject: Disabling The Windows Load Screen
PostPosted: Sat Jun 26, 2004 12:22 am
I lost the issue of MaxPc that tells how to diable the WindowsXP load screen. I did a search and found one, but it's not the same. The one I found shows a bunch of system info at startup. The one I want shows a blank screen until login. Also, in the same issue it tells how to make a one click shutdown and restart shortcut. How? :) Thanks for any help. -Mac
PostPosted: Sat Jun 26, 2004 12:40 am
http://www.annoyances.org/exec/show/article02-011
http://www.tweakxp.com/tweak1880.aspx
 Post subject: Switch User?
PostPosted: Sun Jun 27, 2004 8:05 pm
I read the issue with the 'restart' and 'shutdown' button shortcuts and added them to my desktop. Very cool indeed!
Is there something similar for 'Switch User'?
TIA!
SNAFUE
PostPosted: Sun Jun 27, 2004 10:48 pm
Very nice info. I always wondered how the theme makers changed those starup and shutdown screens.
PostPosted: Mon Jun 28, 2004 8:24 pm
Are you talking about msconfig. Disable GUI boot? I use this and it just sits there blank until logon.
PostPosted: Fri Jul 02, 2004 7:07 am
I found out how to do it. Thanks for your reply. -Mac
PostPosted: Fri Jul 02, 2004 4:15 pm
Sweet.
PostPosted: Sat Jul 03, 2004 6:37 am
been using them ever since i saw the article pu them on all my pc's
