It is currently Wed May 22, 2013 1:40 pm
 Post subject: asus sli deluxe
PostPosted: Mon Feb 28, 2005 4:52 pm
i just ordered an asus sli motherboard from monarch yesterday. And today i just saw the sli mobo roundup on anadtech.com and the results show that the msi and the dfi one are better. should i cancel the order on the asus board? what do you guys think and why?
PostPosted: Mon Feb 28, 2005 4:57 pm
Contributing Writer
Contributing Writer
If it's not too late, I would say yes. The MSI is the board to get, IMO. It overclocked just shy of the DFI, there's no stability issues being discussed (that I'm aware of), and had a richer feature set.
That Anandtech article had me take DFI off of my planned upgrade and consider MSI as the frontrunner.
PostPosted: Mon Feb 28, 2005 5:00 pm
ya u should cancel if possible. The msi packs a solid punch against competition.
PostPosted: Mon Feb 28, 2005 5:12 pm
what if i dont plan to oc (cause i have a newcastle core already)?is it worth it to cancel then?
PostPosted: Mon Feb 28, 2005 5:22 pm
Contributing Writer
Contributing Writer
Yes, the MSI had killer stock performance. The A8N-SLI is not a 'bad' board by any means, but the MSI is the better option IMO.
PostPosted: Mon Feb 28, 2005 5:27 pm
ahh it's too late they'll probably ship tomrrow
am i screweD?
PostPosted: Mon Feb 28, 2005 5:30 pm
no. the msi is just a bit better. In most games you will only see max 5 fps increase its nothing big.
PostPosted: Mon Feb 28, 2005 5:36 pm
well i jsut tried calling but it closed already. so i emailed them a request to change it but it will probably ship before they read the email.
here's what i said:
i just ordered a BFG 6800GT pcie and an Asus SLi
deluxe motherboard.
Is there way i can change the Asus Sli Deluxe to the
MSI SLI K8N Neo 4? or will that cost extra and delay
the shipment?
I am Sorry for this inconvience
PostPosted: Mon Feb 28, 2005 5:49 pm
Contributing Writer
Contributing Writer
If you can't change it, don't stress. As mentioned, the A8N is a fine board. I personally have a love affection with Asus, regardless of my open affair with MSI.
PostPosted: Mon Feb 28, 2005 5:53 pm
hahaha infidellity of motherboards
alright im happy then regardless if i dont get the msi board.
PostPosted: Mon Feb 28, 2005 10:37 pm
yup it's too late the asus one is comming...
should i return it ???
or is the assus not all that bad?
PostPosted: Mon Feb 28, 2005 10:38 pm
I dunno, I have seems some Asus A8N-SLI "Kick Ass" awards aver the net, in fact the SLI Gigabyte motherboard has got slightly better reviews then the MSI one.
PostPosted: Mon Feb 28, 2005 11:11 pm
didnt soeone say like in order to have 1000mhz fsb or something like that you have to set the multiplier to 5x or something ? should i do that right when i get my board for a boost in performance?
PostPosted: Tue Mar 01, 2005 12:13 am
Ahh you might wanna check what the best-of-the-best motherboard is in the current issue of MPC :wink:
PostPosted: Tue Mar 01, 2005 7:00 am
Contributing Writer
Contributing Writer
You may want to read this, which came out yesterday:
Anantech Link
Again, Asus is not a bad choice, but MSI has the better option.
PostPosted: Tue Mar 01, 2005 10:23 am
You should just keep the asus board now. The msi is just tad bit better its no biggie.
