It is currently Sun May 03, 2015 4:12 pm
 Post subject: Looking for a budget case,$50 w/ psu, 30-40 without
PostPosted: Mon Feb 28, 2005 11:29 am
Any clues, ideas?
PostPosted: Mon Feb 28, 2005 11:46 am
well i woud never get a case with a psu for 50$. the psu that will prob come with it will be garbage. so ill just give u links to cses without psus.
raidmax case
codegen case, i recommend this one the most for budget
powmax case
there are alot of others. i would go with the codegen one. proof of its l33tness
anandtech gave it edotrs choice gold.
Quote:
We hand our Editor's Choice award over to Codegen's 6209 for its top performance in our thermal benchmarks, a solid construction, as well as features such as a CPU air duct, tool-less expansion slots, and a full set of auxiliary ports. With a price of $32, it is not much more expensive than the others and is well worth the money with the combination of features and performance it provides.
PostPosted: Mon Feb 28, 2005 1:47 pm
this one is definitely a good buy:
http://www.newegg.com/app/ViewProductDe ... 152&depa=0
PostPosted: Mon Feb 28, 2005 6:42 pm
keymaker wrote:
I wish that the industry would catch on to the Sonata's design for the Hard drive.... It makes soooo much more sense, especially when your plugging your power connectors into your video card.... Speaking of which, I wonder why Antec didn't do the same design in that case you listed above, they look a lot alike.
PostPosted: Mon Feb 28, 2005 7:28 pm
I have an antec 2600k that I could sell soon.
PostPosted: Mon Feb 28, 2005 8:17 pm
I should have added this in my original post but you get what you pay for. If you think your going to get a decent PSU for 10 extra bucks your wrong and when your scratching your head trying to figure out why your having random shut downs and crashes, you'll regret it. If you want a good case and a pretty good PSU go for an Antec case w/ a PSU, you'll probably end up paying around $100.
PostPosted: Tue Mar 01, 2005 10:16 am
hey corona, i like the design of the antec sonata hdd bays. i think they are better than the hdd design of the case i posted above. i like that sideways looks better. gives you more room.
Users browsing this forum: bemaki and 6 guests
