It is currently Tue Jan 27, 2015 10:11 am
 Post subject: NEW SYSTEM good? bad?
PostPosted: Fri Jun 25, 2004 10:16 pm
1. Asus P4P800-SE i865PE P4 ATX Audio/GbLAN/1394/SATA/RAID
2. Kingston 512MB KIT DDR400 PC3200 CL3 (3-3-3) DIMM
3. Intel Pentium 4 2.80E GHz 800MHz FSB w/ 1MB
4. Microsoft Windows XP Home
5. Pioneer DVR-107 8X DVD±RW Drive Black
6. Samsung 16X DVD-ROM Drive
this is the core help me add-on. budget about $500.00
Case is a 450 server tower. so there is plenty of room.
 Post subject: Re: NEW SYSTEM good? bad?
PostPosted: Fri Jun 25, 2004 10:35 pm
Get RAM with better timings... Mushkin or Kingston would be fine.
Go with the Pentium 4 2.80C 800MHz FSB w/512KB... it's actually faster than the "E" series... poor engineering :?
Go with NEC's DVD±RW with dual-layer support... available in black, and it should be significantly cheaper.
If you're familiar with Newegg.com, you should be all set :)
PostPosted: Sat Jun 26, 2004 6:17 am
Already have a hard drive?
PostPosted: Sat Jun 26, 2004 3:40 pm
for that motherboard i would get 2 512mb (total 1gb) identical dimms for the dual channel and for the sound card the Creative Labs Sound Blaster Audigy 2 ZS Audio Card the onboard sound is ok but nothing beats sound blaster
PostPosted: Sat Jun 26, 2004 3:45 pm
1) better RAM; i would go with Mushkin Level 1 pack
2) Northwood instead of Prescott
looks good
get a good PSU
PostPosted: Tue Jun 29, 2004 7:41 pm
to be 100% honest, you wont notice the difference with ram with better tiomings, it just makes such a minute difference that it barely even shows up in synthetic benchmarks and you wont even notice it in everyday use,.
PostPosted: Tue Jun 29, 2004 7:44 pm
I went with a pentium and an ati graphics card last year in my pc and wished I would have went amd and nvidia, but that's just me.
 Post subject: What?
PostPosted: Tue Jun 29, 2004 8:00 pm
:roll: ...no, it does show up in benchmarks...depends on what your Pc uses are...my gaming scores did go up for about 8-10fps with lower latency and my overall gaming experience was better....it may not mean much for the average user but latency IS important.
