It is currently Sat May 18, 2013 9:24 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Feb 26, 2005 4:24 am
Folding Momerator
Folding Momerator
I think you need to throw in 2 Sony 19 inch LCD's at close to $700 each. There is a rebate, $100, not sure if they'll give 2 rebates.
SDM-HS95P/B- 19" HS-Series Flat Panel Digital Display, they also make it in silver.
Then there is the SDM-HS94P/S- 19” HS-Series Silver Flat Panel LCD Display.
Awesome monitor. I just bought the SDMHS74P 17 inch monitor, circuit city link and am really impressed with it.
If a monitor is on your list, go to either Best Buy, Comp USA or Circuit City and check them out.
PostPosted: Sat Feb 26, 2005 4:52 am
Smithfield*
Smithfield*
MC-Screwdriver wrote:
Do you know is the new Antec Cooler is any good? Because I'd much rather go with something like that as opposed to changed the actual cooler. It could even cool my extremly power hunger constantly overheating audigy 2 ZS. :P :wink:
thats the two slot pci cooler i was talking about, that'd work great if you can spare some PCI slot room
PostPosted: Sat Feb 26, 2005 11:53 am
that's a great deal, but I already have the Dell 2001FP, and i'm thinking about buying the 24" widescreen version that's coming out in May, I beleive.
PostPosted: Sat Feb 26, 2005 5:11 pm
Folding Momerator
Folding Momerator
Oh well, it's an awesome monitor.
PostPosted: Sat Feb 26, 2005 5:15 pm
OCNoob that isn't that best ram for the price for overclocking very high.
PostPosted: Sat Feb 26, 2005 5:55 pm
Would you recomend it over my curent one? :shock: I really don't mind lsoing an extra inch if it's better. :)
PostPosted: Sat Feb 26, 2005 6:10 pm
Celeron
Celeron
You think I should have recommended OCZ VX or...?
PostPosted: Sat Feb 26, 2005 6:19 pm
Well right now I think I have most components chosen:
AMD Athlon 64 3200 w/ ZALMAN 7000b Copper heatsink
DFI LANPARTY UT Ultra-D or Asus A8N SLi Deluxe
1 GB OCZ Platinum Rev. 2 Enhanced Latency
Leadtek GeForce 6800 GT or Powercolor X800 XL*
300 GB Maxtor DiamondMax 10 or 74 GB WD Raptor
*I was also looking into 2 Vanilla 6800s in SLi
Right now though, the real question is, what'sa good case to keep everything nice and cool, I was thinking of the following:
CM Centurion 5
CM WaveMaster
Antec P160
Chenbro Gaming Bomb II
PostPosted: Sat Feb 26, 2005 8:59 pm
bump...need more suggestions...
PostPosted: Sat Feb 26, 2005 9:01 pm
CM Centurion 5
CM WaveMaster
Antec P160
i would go with the dfi sli mobo, 2x 6800 vanilla sli, 300gb hd, and coolermaster cmstacker
PostPosted: Sat Feb 26, 2005 9:36 pm
Thanks for the recomendation, but the Stacker's not my cup of tea, too heavy, BTW do you know how 2x Vanilla 6800s perfrom to an X850 or 6800 Ultra?
PostPosted: Sat Feb 26, 2005 11:10 pm
Max [Ph]otographer
Max [Ph]otographer
You should look at some benchies.
Last I saw, the Ultra was about 10% faster than the vanilla. However, 2 vanillas are about 25-75% faster than 1 vannilla depending on which game it was benched on.
Basically, I think you would be looking at about 40% faster than an Ultra with 2 Vanillas.
EDIT: Found some benchies, though they only compare the 6600GT and the 6800Ultra in SLI.
Damn! Look at that benchie! 2x 6800 Ultras in SLI can do 1600x1200 with 4x AA and 16x AF at 65FPS! :shock:
It looks to me like HL2 gets more out of SLI with higher resolutions and filtering. If you plan on having a lot of that, go for the SLI.
Dan O.
PostPosted: Sat Feb 26, 2005 11:12 pm
:shock: Really? I posted this same thread over at PCG Forums and someone over there said it'd only be a tad faster than a single GT. :?
PostPosted: Sat Feb 26, 2005 11:20 pm
Max [Ph]otographer
Max [Ph]otographer
Read my edit statement.
At 1024x768, the difference will be nil. However, at 1600x1200 and 4x AA with 16x AF, you will see close to a 100% increase in FPS.
EDIT: It looks like SLI also helps with water. Compare the Canals benchies to the City 17 benchie.
Dan O.
PostPosted: Sat Feb 26, 2005 11:29 pm
Well i do have a Dell 2001FP, so the greater resolution is great, but I've been hearing thins about the Vanilla 6800 being similar to the 6600 GT.
PostPosted: Sun Feb 27, 2005 6:10 am
Folding Momerator
Folding Momerator
If your close to one of the stores I mentioned, go check it out, it's an awesome monitor. I've never seen the one you have to compare it to, if you do go, post back on your thoughts.
PostPosted: Sun Feb 27, 2005 8:47 am
no thats the 6600gtsli. when they sli they are abt on par with the 6800gt. 6800 vanilla sli should be about the same as a 6800 ultra (i think).
You said the cmstacker wsa too heavy, i would go with the wavemaster then. Also i think instead of u gettting 2x 6800 vanilla u should get 1 6800ultra and get another on a later date.
PostPosted: Sun Feb 27, 2005 8:51 am
also how abt getting this ot this
come on liquid cooling!
PostPosted: Sun Feb 27, 2005 8:55 am
Dan O.
in this benchie it shows sli 6800ultra getting over 100fps in 1600x1200 with aa and af.
PostPosted: Sun Feb 27, 2005 9:01 am
I think I'll go with a single 6800 GT for now, an OC to Ultra speeds.
